RV.Net Open Roads Forum: Toy Haulers: First RV,Travel Trailer, Toy Hauler ever!
Search only in Toy Haulers
 > First RV,Travel Trailer, Toy Hauler ever!
WEOUTHERE
OrangeCounty
Posted: 01/10/23 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Another tidbit I noticed, the FSC3200 has an GVWR of 13k and ULW of aprox 10,800 from what im reading with 3k or less or CCC.
The Forest River has a GVWR of 16,379 with an ULW of 9,360 and CCC of 5,827!
Seems like the river would be a better choice to carry a 2800lb or so car, what you guys think?
dsrace
home
Posted: 01/11/23 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Maybe its just the picture but the sand storm looks like It has a bent ladder. Or I should say the top of the ladder looks bent backwards like they ran into something. Both will be a handful to tow at higher speeds in wind. Basically you need the one with 4500 lb plus cargo capacity.
WEOUTHERE
OrangeCounty
Posted: 01/11/23 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yes Ds the ladder is bent but it is an 09 and cheaper the the WW with he same floor plan and two years newer and has almost double the payload so prob will end up with the FR...
valhalla360
No paticular place.
Posted: 01/12/23 01:44am Link  |  Quote  |  Print  |  Notify Moderator
Double check the cargo stats. I tried to pull up what appears to be the model (it's not listed) and it shows a 14000lb GVWR, so about 4600lb cargo capacity. Probably adequate but I would want to run it by a scale before purchase as add on items can eat up a fair amount.
Also, what is your hitch rated for? At 1400lb, I would expect a hitch weight of around 2000# give or take once loaded. It likely will be worse when running without the 2800lb car in the garage. Keep in mind the weight distribution of the car can make a big difference.
Probably doable but what's the full truck info. While payload is often a limiting factor, this might be an oddball where something else becomes the limit.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
dsrace
home
Posted: 01/12/23 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Never know when looking at pictures. Based one your response, it seems like the better choice......as long as there is damage to the roof from what ever they struck. Or at the very least, more damage then your willing to fix. Beyond that, it sounds like the better choice based on ccc.
WEOUTHERE
OrangeCounty
Posted: 01/12/23 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
So 360 ill post the info from inside the trailer but the truck is a 15 LB DBL cab Duramax SRW and hit I will be using is a Propride3.
DS seller says there is no roof damage what so ever, just the ladder...
Thanks to both you guys for the help! I will get a pick of the label of weights ect on the FR and post it asap
WEOUTHERE
OrangeCounty
Posted: 01/12/23 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
This should be the image of the label with the info on the FR...
WEOUTHERE
OrangeCounty
Posted: 01/12/23 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
This should have the numbers...
Mod Edit: FB pictures often don't work here is a link that may work.
* This post was last edited 01/13/23 03:49pm by an administrator/moderator *   View edit history
WEOUTHERE
OrangeCounty
Posted: 01/12/23 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Hey 360 these are the numbers from the FR...I tried looking the model up as well but there isnt a ton of info on them online so to be certain I had the owner send me the label from the trailer itself so I know for sure what the specs are.
These numbers seem correct to ya'll?
dsrace
home
Posted: 01/13/23 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
if that is the label from the toyhauler then yes, that would seem correct. that is one of the better ones for ccc ! not sure i would travel far with 135 gal's of water in tow but you **** sure can in that unit.
