RV.Net Open Roads Forum: Class A Motorhomes: generator fuel line
 > generator fuel line
Gjac
Milford, CT
Posted: 01/16/23 10:53am Link  |  Quote  |  Print  |  Notify Moderator
TechWriter wrote:
David0725 wrote:
I have a 2003 Duch star on a spartan chassis. I figured out the fuel line to the gen set must have an air leak. Or something I have to keep bleeding the gen set. Has anyone ever had with problems and got it fixed? It runs great from a 5 gallon can.
Have the identical problem. Dropping my fuel tank is the LAST thing I want to do to fix it.
My current "fix" is to detach the fuel line at the generator, connect it to a pump action siphon, and start pumping until I get flow. Then reattach to the generator.
However, I'd like a better more permanent fix before dropping my fuel tank.
So I'm going to try the "catheter" approach. Got this idea during an angiogram when my doctor routed a catheter up my arm vein into my heart. Very slick.
I'm buying a small fuel line to run inside my current fuel line.
We'll see.
I had this same thought I spent hrs trying to fix it without dropping the tank. I had some small dia plastic tubing which was stiff enough to push through, but it could not make the right angle bends. I think the fuel line would be much softer and would tend to bunch up when you push it in. Dropping a near empty tank was not so bad, probably an hr to actually drop it, going to the parts store to buy a new line installing the line, and reinstalling the tank was about a half day when all was said and done.
wallynm
Los Alamos NM
Posted: 01/20/23 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yes and it took me a year to find it. I extended the generator slide all the way out and traced the like to the MH fuel tank.
David0725 wrote:
I have a 2003 Duch star on a spartan chassis. I figured out the fuel line to the gen set must have a air leak. Or something I have to keep bleeding the gen set. Has anyone ever had with problems and got it fixed? It runs great from a 5 gallon can.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
