RV.Net Open Roads Forum: Tech Issues: burbing fridge
 > burbing fridge
dougrainer
Carrolton, Texas
Posted: 01/12/23 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Blockages are as hard as a weld and are attached in the upper coil area and CANNOT be broken loose. So, burping just rearranges the Ammonia temporarily to work a little longer. It works but NOT AS WELL AS BEFORE THE BLOCKAGE. IT WILL FAIL AGAIN. Rebuilders cut out the tubing where the blockage is on blocked units and then weld a new upper tube assbly in place, then charges the cooling unit. THERE IS NO WAY THAT MOBILE TECH FOUND A BLOCKAGE, UNLESS HE STUCK AROUND FOR 2 OR 3 DAYS AND DID VARIOUS TESTS. TEMPORARILY UNBLOCKING A UNIT REQUIRES THE REFER TO BE TURNED UPSIDE DOWN FOR 24 HOURS AND THEN RIGHT SIDE UP FOR 24 HOURS. Then start a cooling process. You could have just had a glitch and if the refer continues to cool (below 38 degrees in the refer and below 10 degrees in the freezer), I would not worry about it. Also, it could have been as simple as the rear cooling fans did not run. Did the Mobile tech checked those? Doug
PS, is the refer in a slide room?
Posted: 01/12/23 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
If you plan on living in the RV.. Do you plan on MOVING it or parked on/near construction of new house site.
If the latter.. Consider the "new Fridge" for the new house... Have it on hand.. (You need not unbox it unless you fear warranty expiring) If the RV fridge fails.. Unbox. plug in and use.. Or better (less energy needed to run it) Use it instead of the RV unit... And when new house ready.. MOVE IT.
MrRetired821
Posted: 01/12/23 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
The tech used a heat measuring gun and found the top tube hot on the left side and it cooled off right in the middle and continued cool the rest of the loop. Seems logical to me that where the heat stopped and the cool begin theres the problem.
The fridge is in a slideout. One of the fans was stopped up with mud dobbers nesting on it. Once flipped, it gurgled a few minutes and then we flipped it right side up. powered up and working still. Steady 34 degrees in fridge.
Note: we were camped in Davis Mountain State Park and temps got down to single digits a couple of days before it quit working.
thanks
Mod Edit: fixed the quote
* This post was edited 01/13/23 08:38am by an administrator/moderator *
Smokey&Bobbye
trailrider
Idaho Is Full! Don't Move Here!!!
Posted: 01/12/23 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
Temps got down to single digits?
There is your problem.
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
dougrainer
Carrolton, Texas
Posted: 01/14/23 09:28am Link  |  Quote  |  Print  |  Notify Moderator
thanks
AS I stated, NO BLOCKAGE. The fan was the problem. Also, to make the refer operate BETTER, I install an additional 12 volt cooling fan at the upper outside vent door blowing OUT. This is really needed for all slide room installed refers. IF any blockage, you would NOT get 34 degrees. The heat gun showed high temps because with inadequate ventilation the cooling unit overheated slightly. Doug
joebedford
Made It!
Posted: 01/14/23 09:33am Link  |  Quote  |  Print  |  Notify Moderator
MrRetired821 wrote:
my better half says get a new cooling unit.
There's your answer.
MrRetired821
Posted: 01/28/23 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Well mobile tech just installed the new cooling unit. Put fridge back into hole and it works like its supposed to.
thanks for all the replies.
 > burbing fridge
