enblethen
Moses Lake, WA
diaphragm in regulator
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
bobndot
enblethen wrote: diaphragm in regulator
X2.
I had one crack in cold temps snd had to replace it. Cheap enough to buy a new one.
enblethen
Moses Lake, WA
Would also check the flex hose between regulator and the black iron pipe.
opnspaces
San Diego Ca
Take the trailer out of the picture. Disconnect the rubber hose on the tongue right at the iron pipe and put the manometer on the end of the hose. Does the 2 minute drop happen indicating something on the tongue?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
SCADAMAN29325
Clinton, SC
All good stuff above, but I have found 2 problems.
1- regulator to tank connector was loose! I had found it loose before and retightened (hand tight). This time I moved the "c" ring and moved the plastic hand wheel out of the way so I could get to the nut and put a wrench on it.
![[image]](https://i.imgur.com/1mwpp2ul.jpg)
2- Ordered one of those gas sniffers and been hunting the leak. That took a while: turned gas on, went round and round, inside and out for over an hour, nothing! Left the gas on for 2 more hours... tester went off like a rocket inside the furnace housing outside after removing the cover! Went inside to confirm the furnace was off, it was.
Now I need to figure out how to test the furnace system. I want to make sure the thermostat is actually turning off the furnace and it is not a bad thermostat. Then check to make sure the valve is closing the way it should (I think this will be the problem).
STILL, I don't see how the furnace valve being stuck open would cause the propane alarm to go off when going 60mph down the highway. Scratch that, 10mph start/stop traffic congestion.
It has gone off 3 times, once the last night of a week long camp in February, next in that start/stop traffic, then most recently when having the fridge cooling down the day before leaving for a short boondocking experiment.
So this where I am now, troubleshooting the furnace system.
TTYL, Phil
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19.
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
SCADAMAN29325
Clinton, SC
HydroFlame 8531-ll 12v 8.2 amps
Hmmm??? (Edit for clearer pic)
edited 04/05/23 08:52pm by SCADAMAN29325 *
SCADAMAN29325
Clinton, SC
I think it's going to be the valve, but 1st this video
Edit: more like it opens when not being told.
NOT Valve, control...
Check for continuity (voltage?) across the 2 blue wires before and after water column drop. And battery voltage across red/yellow.
![[image]](https://i.imgur.com/BMdTTrAl.jpg)
Edit again: that's strange, even without the control board plugged in I detected gas in the exhaust port. Hmmm...
last
edited 04/06/23 10:34am by SCADAMAN29325 *
View edit history
SCADAMAN29325
Clinton, SC
Too Long, Don't Read?
I think I need to replace the propane valves on the water heater AND the furnace. The propane sniffer is going off near the burners of both appliances!
Update:
April
I took it to the service guy to replace the gas valve, but he found a loose fitting and tightened it up. (Yeah, it was loose because I couldn't get it out without buying more tools).
When I got it home everything was fine. Saturday, the next morning the LP alarm was going off again. Called the dealer, service desk said to check battery voltage, it may alarm on low voltage. Checked it, 12.4. Called back and told them to put a note on record about this and I will get it taken care of after we get back from our trip.
Fast fwd to August (it felt like we were camping every other week for 3 months! It wasn't that often, but felt like it. We took two groups of grandkids with us several trips. That was fun.)
The beginning of Aug I was going to test the propane again. When I turned on the propane I could feel it hissing out from around the valve stem. ****, so we took it to the shop to replace the valve on the propane tank. 2 days later they called and said it was ready and that it wasn't the valve, just a loose connection at the POL fitting. (I should have caught that myself!) Go it home, turned on the propane and it was still hissing around the POL valve! I took the regulator off to check it out. The o-ring looked chewed up, so I went to Ace Hardware to get a new one. BTW, it was 5/8 x 7/16 x 3/32, bought 2.
Now let's test again. Turned on propane, 24hrs later, no alarm, the next day it was alarming again! Broke out the propane sniffer, NOTHING. Could not get it sniff anything. MAYBE it wasn't sensitive enough. Checked the specs, should alarm at 50ppm. Checked the detector, it was saying 17x100ppm, 1700ppm. The sniffer should be going off! Hmmm, took it outside the sniff around the tank, nothing. But it did go off in the water heater burn tunnel. (Same as the furnace when all this started!) ALSO, when we do use the water heater on propane, everytime it lights there is a small explosion like a pop-whoosh-burn, but that may be normal, OR it could be that the burn tunnel is full of propane and the explosion may be larger than it should. (Again, same as the furnace.)
Right now I've moved onto other items on the todo list. I think I'm going to make sure the propane is off (it is now) clear out any propane from inside the water heater and furnace and start testing again.
There is a leak somewhere and I need to find it and fix it so we can use the furnace in a few months when it turns cold.
Still having fun with the camper!
TTYL, Phil
