ford truck guy
Pennsylvania
mkirsch wrote: Thomas/NH wrote: mkirsch wrote: If you're willing to pay the $1000's extra for an F250 over an F150, then why are you quibbling over the $300 of shop time to have the hitch installed? That's 2 hours of shop time these days, which is about right.
Say what??? When was the last time you went truck shopping? There is very little differnce between the 150s and the 250 or the 350 set up the same. Availability of trucks is another issue. Yes, I've been shopping and very discouraged by the lack of inventory. My local Ford dealer usually has hundreds of trucks on the lot, only had 6 Super dutys and 35 F150s.
Don't know where you've been but the difference between 1/2 tons and 3/4 tons is about $10,000. Trim level for trim level.
Of course if you compare a mid-trim F150 with a base F250, the price is about the same. That's not apples to apples.
I ordered a 2022 F150 platinum AND a 2022 F250 Platinum, both speched as close as possible... they came in and the sticker was just about $4500 higher on the F250... BTW, there is a 2022 F250 Platinum in Feasterville PA if anyone wants one ! !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Or the short answer to your actual question. Yes I would absolutely get the truck n trailer and then decide what you need.
How can you buy a trailer with no truck AND make the right decision on accessories when you don’t even know fundamentally what size truck you’re getting?
This is IMO the logical order of operations.
1. Decide roughly what size/weight/configuration of trailer you want and be certain about that.
2. Buy truck suitable for that trailer taking into account whatever you need to.
3. Buy trailer.
4. Buy or don’t buy accessories based on the first 3 and your comfort level towing it.
And another off the wall suggestion. If you’re getting a 9klb gross TT, she’s a pretty big girl.
Have you considered a small 5th wheel camper instead? Not confusing the issue here but if you’re gonna be pulling it all over the country, may as well get a setup that tows better overall. If not a lot of trailering miles, then disregard, as apples to apples IMO the additional cost is not justified if not realizing the value in ease of towing.
KD4UPL
Swoope, VA
Get the F250 and you shouldn't need to fool with the WDH.
Thomas/NH
Exeter, NH
Thomas/NH wrote:
Remember what I said: Not all F150s are equal. There are the "Air Haulers" and then there are the work horses. Since my trucks have to work every day with either the service cap/tools or hauling my trailers. I also haul a 5-ton dump trailer at least once a month. My last Heavy Duty F150 hauled my Reflection 313 RLS (11,000 lbs.) 37,000 miles and it had 1,400 lbs. tongue wight. The truck had more advanced electronics, a better ride, better mileage and a better safety (that truck actually cared who was riding in which seat). My F350 (same trim level) is such a dumb truck and its 5 years newer. Short of my $10,000 Diesel option both trucks cost about the same. Make no mistake about it, you will most defiantly need an equalizing hitch for that trailer for either truck.
Here's a little more information for you... The reason I stepped up from the F150 (Eco-boost) to a F250 (6.0) was because I noticed the receiver hitch was distorting from hauling the heavy trailer (1400 lbs. tongue weigh). Crawling under the truck for a close inspection I noticed the hitch was stamped with a 1000 lbs. hitch/10,000 gorss capacity (class 4 I think). I traded in the truck for the F250 with the same trim level. After 10K of towing I noticed that hitch with (2-1/2" reviver) was also distorting. On close inspection it was also stamped with the same rating, it just looked beefier. The F350 has done a much better job towing, but it's equipped with B&W 30K Gooseball. The receiver hitch only gets used for the smaller trailers and I suspect it is the same class 4 hitch, which is fine.
nickthehunter
Midwest
Boomerweps wrote: ...
If you go the F150 route, get the Max Tow (53C) for the reinforced hitch & a thicker frame...
Just an FYI so no one is led astray, although there are several different thicknesses of frame depending on the configurations of the F150, the thickest frames are with the Heavy Duty Payload Package option, not the max tow package. Regardless, you need to choose the vehicle based upon the payload you need and the frame will be appropriate for the load.
Clicky
And also to not lead anyone astray, there isn’t a half ton truck made in, since about forever, that is t strong enough to tow a 9klb trailer….
It’s a moot point
DallasSteve
I also did a quick comparison of the prices on Ford.com and the F250 appeared to be about $5,000 more for the cheapest models. But the cheapest F250 probably tows much more than the cheapest F150, so that seems like a bargain to me. Now the actually prices that dealers are getting is another story.
I want something with a towing capacity of at least 10,000 pounds to tow a trailer with about 9,000 pounds. The F150 ranges from about 5,000 to 14,000 so if I am looking for an F150 I have to be considering the different combinations of motor, gear, bed, cab, yada yada. The towing capacity on an F250 starts at 12,000 pounds. Problem solved.
edited 01/14/23 08:11am by an administrator/moderator *
2022 JAYCO JAY FLIGHT SLX 8 324BDS
2022 FORD F-250 XL CREW CAB 4X4
All my exes live in Texas, that's why I live in an RV
JBarca
Radnor, Ohio, USA
DallasSteve wrote: I'm buying a bumper pull trailer and the dealer is offering to install a weight distribution hitch for $1,000. They said it is an Equal-i-zer, I don't remember which model. It's my first trailer so it may be nice to have it set up, but I'm pretty sure I could watch a YouTube video and do it myself. I installed a base plate on a Jeep. I checked Amazon and I see Equal-i-zer hitches for around $700. GVWR on the trailer is about 9,000 pounds. I'm planning to tow it with an F 250 though I might get an F150 if people think that's plenty. The difference in price isn't a big deal. Would you pull it first and then decide if it feels like it needs the WDH?
Hi,
I will mention a few things not yet discussed.
First off, the WD hitch.
Make sure the WD hitch the dealer is calling an Equalizer is made by Progress Manufacturing which makes the 4-point brand "Equal-I-zer" WD hitch. A classic camper buying mistake for first-time trailer buyers is, the dealer-supplied an equalizer hitch, as they called it, which can be almost any other brand WD hitch. Generally, the cheapest one they can throw in is with a friction anti-sway bar. This is a very different WD hitch than the branded Equal-I-zer WD hitch.
Another dealer-supplied classic mistake is on the sizing of the WD hitch. If you have never been through this before, you expect them to give you the correct size for "your" camper. It only sometimes works that way. The WD hitch "needs" to be sized for the "loaded" tongue weight, not the dry (empty) tongue weight. If they give you a standard, cheaper WD hitch rated at 1,000# tongue weight, and after you load the camper, you find out you have a 1,200# tongue weight, you have the wrong WD hitch.
The floor plan also drives the loaded tongue weight. Some floor plans load heavily towards the front, others less. This comes from the experience of knowing how to help predict the right size WD hitch needs to be. Too light is no good, and way too big is no good. Since you have a 9,000# GVWR camper in mind, 15% TW is 1,350#, 12% TW is 1,080#. And since you are looking at the Equal-I-zer brand hitch, that brand needs to have the whole hitch head and WD bars changed to jump sizes. So ideally, spend some time sorting out which WD hitch would fit your fully loaded floor plan. Odds are high, sooner or later, you will load it fully. Many of us do... If you tell us the make, model, and year, of the camper, we can help suggest the right size WD hitch.
Once you have sorted out the expected loaded TW, next comes the truck receiver and payload. The truck receiver needs to be rated at or above the WD hitch rating when in WD mode. The F150 might be WD mode limited below your needs.
Now comes the truck and payload; you are talking about an F250 or an F150. Pulling the camper is one thing; carrying the load of the camper TW, truck bed weight, and all passengers is a big difference between an F250 and an F150. What are your expectations for bed weight and people's weight? Are you going to have a truck cap? While the right-sized F150 might be able to pull the camper, can it handle all the added weight?
Where are you going to tow at? Long trips, short trips, higher elevation? Is the truck only needed for towing mainly, or is the truck your daily driver, and towing is a small amount of distance and time?
For my camping situation, given a 9,000# camper, I would go with the F250. But that is my case. I started out a long time ago with a truck that could pull the camper OK but could not hold up the weight once everything was loaded to go camping. And the larger truck makes for a more enjoyable towing experience. You do not have to get a diesel, the right-sized gasser truck will do you well.
Hope this helps.
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
MFL
Midwest
It's not just how much will it pull, 150-250, but the rear axle and tire capacity difference is huge in comparison. A trailer weighing 9K lbs will have a heavy tongue, plus any other wt added to truck bed, which is mostly being carried by the rear axle.
Jerry
valhalla360
No paticular place.
That's been my experience...not much difference in price.
That said, $1000 seems kind of high. We had a hitch with installation thrown in for $600 a couple years back during the height of the RV boom.
Yes, a 3/4 ton will tow better with or without a WDH but generally nicer with. Our F250 with WDH tows like a dream. We've had it in 40mph cross winds and no sway. We also have a decent percentage hitch weight (13%) which the F250 has no issue with. With some marginal 1/2 ton trucks, people try to keep the hitch weight down which makes sway more of an issue.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
