RV.Net Open Roads Forum: Towing: Should I Buy The Dealer's Hitch
Search only in Towing
Open Roads Forum  >  Towing
 > Should I Buy The Dealer's Hitch
Page of 5
MitchF150
Puyallup, WA
Posted: 01/13/23 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
I'm an F150 tower, but I'm only towing about #7000. My F150 has a "tow rating" of #11,000.. It's MaxTow, has #7700 GVWR and #1900 payload according to the door jamb sticker. All fine and dandy, right..
Well, I've been towing stuff of different combinations since the mid 80's.
At this point in my life, I like a nice comfy tow. Not a maxed out load that sure, all the bench numbers match up, but out on the open road with all the other Nuts out there... No thanks. [emoticon]
If your new trailer "can be loaded" to #9000 GVWR, chances are, over time, you'll get that heavy. I know I'm at my trailers #7000 GVWR, as I pack heavy, carry all the water I want to and don't worry about it! [emoticon]
I have just a simple WD hitch setup. Just a #1000 bar and chain setup. Dealer charged me $350 for it back in 2003 when I used it on my 1997 F150.
I transferred that hitch to my 13 F150 and it's still just fine for my towing comfort.
Anyway, I'd get the F250 for your choice of trailer and maybe get just a basic WD hitch setup. All those fancy and $$ hitches are all fine and dandy and have their purpose in life.. They give the owners of them a comfy tow and that's the main thing, as the point of getting out in an RV is to be relaxed and comfortable, right?
Good luck! Mitch
katysdad
Virginia
Posted: 01/13/23 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure about todays 150s but P series (passenger car)tires were the most common. They have a lower load capacity and softer sidewalls for a smoother ride but will have more side sway giving a less desireable towing experience. Switching to LT (light truck) series will have a higher load capacity, stiffer sidewall and give a better feeling of control when towing. They will ride a little stiffer but worth the feel for towing. Any type of WD hitch will improve the ride with that size trailer especially on rough roads. And from experience working at an RV dealership most travel trailers actually had a tongue weight higher than advertised.
Dodge Ram 3500 DRW Diesel
dfm
B.C.
Posted: 01/13/23 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have towed an rv for 57 years and have NEVER yet met a fellow rv'er complaining they have too much truck to tow their rig. I have met and seen many , many who were not happy with their towing experience or were not towing safely. GET the 250!!!
I have used many equalizer "named" hitches and they were fine BUT when I got
my present trailer I bought the Reese dual Cam hich. It is the best of all of the hitches I have used over 57 years.
2015 Open Range 340 FLR
2012 Ram3500 Laramie Longhorn/Cummins
1 DW 1 Furperson
StirCrazy
Kamloops, BC, Canada
Posted: 01/14/23 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
should you pay for it no, you should make the hitch part of the deal and get them to throw it in. they spen like 150 bucks on that and I have never seen anyone pay for a hitch when they are buying a new trailer.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Boomerweps
Hills of PA
Posted: 01/15/23 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Thomas/NH wrote:
Here's a little more information for you... The reason I stepped up from the F150 (Eco-boost) to a F250 (6.0) was because I noticed the receiver hitch was distorting from hauling the heavy trailer (1400 lbs. tongue weigh). Crawling under the truck for a close inspection I noticed the hitch was stamped with a 1000 lbs. hitch/10,000 gorss capacity (class 4 I think). I traded in the truck for the F250 with the same trim level. After 10K of towing I noticed that hitch with (2-1/2" reviver) was also distorting. On close inspection it was also stamped with the same rating, it just looked beefier. The F350 has done a much better job towing, but it's equipped with B&W 30K Gooseball. The receiver hitch only gets used for the smaller trailers and I suspect it is the same class 4 hitch, which is fine.
I STRONGLY suspect the 1000# TW/10000# towing on the F150 was the “ with a weight distributing Hitch” value and the F250 same value was for the weight carrying tow stats.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
Posted: 01/16/23 11:22am Link  |  Quote  |  Print  |  Notify Moderator
He’s all confused about his truck models anyway, and none of this has any bearing on the OPs question.
Oreonut
DE
Posted: 02/22/23 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Reading on all this hitch talk trying to figure out what we should purchase. For 14 years we towed a 32' Sunny Brook using a Hensley. Like dummies we sold the whole thing as one unit.
Here we are two years later missing camping and starting all over again. We will have a Chevy 2500 and possibly a Forest River Wildwood 31KQBTS rolling in at a total of 36'7" - weight at 8573.
Not as heavy as our previous trailer but 3' longer.
Been out of the game for a long while and not sure whether to dump the money on a ProPride or if other hitches have come along way since 2006 and something else would be just as good.
Any suggestions??
Thanks!
Kelly
2023 Chevy Silverado 2500 HD
2023 Forest River - Wildwood 31KQBTS
Blue Ox
Old Set up:
2006 Chevy Silverado 2500 HD
2007 Sunset Creek 298 BH
Hensley arrow/Prodigy
Bobbo
Wherever I park
Posted: 02/22/23 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
The Propride/Hensley folks will say nothing else is as good, but I love my Reese Strait-Line hitch.
Bobbo and Lin
DallasSteve
Posted: 02/22/23 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Any suggestions??
Thanks!
I've decided to step up to an F250 instead of an F150. I'm going to wait and see how it tows before I decide if I really need a WDH. With a Chevy 2500 you might want to do the same. Some other readers made that suggestion and it makes sense to me. I'm going to have about the same size trailer as you and I will have much more truck than I need.
2022 JAYCO JAY FLIGHT SLX 8 324BDS
2022 FORD F-250 XL CREW CAB 4X4
All my exes live in Texas, that's why I live in an RV
opnspaces
San Diego Ca
Posted: 02/22/23 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
I've never towed my travel trailer with anything less than a 3/4 ton. My current is a bit over capacitied for my little 6,000 lb trailer. But there have been a few times that the wind hit me just right and I was glad I had a 3/4 ton and equal-i-zer.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Page of 5
