RV.Net Open Roads Forum: Truck Campers: Crack in plastic shower wall Lance 1172
 > Crack in plastic shower wall Lance 1172
Geterdone
Henrys Bend Pa.
Posted: 01/14/23 07:32am Link  |  Quote  |  Print  |  Notify Moderator
We noticed a crack running along the wall of our shower just below the spigots and runs to curve on back wall. Is there a practical way to repair this or must the shower walls be replaced ? This is in a 2013, Lance 1172.
Steve and Patti, 2014 Ram Duelly, Longhorn Laramie, Lance 1172 solar,Genset, torklift super hitch, and tiedowns, Bodiak front hitch,Polar Kraft boat when trailered.
pianotuna
Regina, SK, Canada
Posted: 01/14/23 09:19am Link  |  Quote  |  Print  |  Notify Moderator
It is possible to weld the crack.
Regards, Don
daily double
ketchum ok.
I had the same thing happen in another camper. Took it to a good fiberglass repair place and it looked as good as new!
ssthrd
Vancouver Island
Posted: 01/14/23 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the size/length of the crack. Sounds like it may be minor. If so, after removing the tap set, I would drill a small hole-maybe one eighth inch-at the end of the crack so that it won't run anymore; "vee" out along the crack with a Dremel or v-file; fill the crack with epoxy; sand smooth with 220 grit or finer after epoxy sets.
Replacing the shower surround could be a big job involving more than just the surround.......damage to walls, new taps, modify water lines, etc.
In my mind, and without seeing it, I would go with the repair unless you have the aptitude/ability to replace it yourself.
Good side is that it won't leak, bad side might be that the colours may not match.........
Hope this helps...........
* This post was edited 01/14/23 02:32pm by an administrator/moderator *
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
ticki2
NH
Posted: 01/14/23 10:26am Link  |  Quote  |  Print  |  Notify Moderator
There are also folks who socialize in this . Look up shower an bathtub repair near you
'68 Avion C-11
'02 GMC DRW D/A flatbed
bukhrn
Lanexa, Va
Posted: 01/14/23 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
The one in my Class C did the same thing, i fixed it with epoxy, I'm not a pro, and it doesn't look like a pro did it, since DW and I are the only ones that have to look at, it really doesn't matter all that much, but it worked.
2007 Forester 2941DS
2014 Ford Focus
d3500ram
Colorado
Posted: 01/14/23 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
I had a crack in the base of my last camper and this is what I did:
I drilled a hole at the end/ apex of the crack in hopes any forces would disperse around that hole and not continue further.
I filled the crack/ drilled holes as best I could with flexible caulk and applied an appropriate size piece of trimmed- to- fit EternaBond over it.
StirCrazy
Kamloops, BC, Canada
Posted: 01/14/23 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
do you need it pretty? or just functional. I had one appear in my suround and I found the almond Geocell calking did a fine job of sealing it up and holding it togeather.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Buzzcut1
Norcal
Posted: 01/17/23 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Places that do Fiberglass boat repairs can probably fix that right up for you and make it look good.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
mkirsch
Rochester, NY
Posted: 01/18/23 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Is it fiberglass or some sort of acrylic?
In my experience NOTHING sticks to acrylic. Had a cracked shower pan in my TC. Tried epoxy, no dice. Fiberglass and resin, fuggeddaboutit. No amount of roughing and cleaning would make it stick. Like eggs off a teflon pan.
If fiberglass, you've got it made.
