RV.Net Open Roads Forum: Class A Motorhomes: Slides out or autolevelers down first?
 > Slides out or autolevelers down first?
AllegroD
Outdare
Posted: 01/15/23 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
What does your manual say?
wildtoad
Blythewood, SC
Posted: 01/16/23 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Be nice to know the brand of is current mh, and what chassis. As others have stated check your manual and/or call customer support.
I have a Newmar gasser and won’t say what I do, as it may not be relevant for your needs.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Dutch_12078
Winters south, summers north
Posted: 01/16/23 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with the check the manual recommendations. It makes a difference whether you have leveling jacks or air bag leveling.
Dutch
2001 GBM Landau 34' Class A
willald
NC
Posted: 01/17/23 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Here's another vote for "Ignore the blanket statements, and just go by what the owner's manual says". That is ultimately what matters, and the answer will not be the same for all coaches.
For us, most times we deploy the jacks and level things up first, but not always. If we pull into a spot that feels fairly close to level, I've been known to let the slides go out first. Or, if we are boondocking for just one night in a parking lot or something, we will not use/extend the leveling jacks at all, but the slideouts will come out.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
Blaster Man
Posted: 01/17/23 07:40am Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
Always level first. Otherwise if off level the slides can and will go out uneven and may cause damage.
For Sure!
2014 American Eagle
Ro"n"Joe
Full Timing
Posted: 01/17/23 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
On our rig, while aired up slides out first then level. On leaving air up bags, slides in then jacks up.
2020 Dutch Star 4328 on FL Chassis
2018 Grand Cherokee Limited
Ready Brute Elite Towbar & Road Master Wiring
Bruce Brown
Northern NY
Posted: 01/18/23 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
That must be something new for Newmar, they were always level first then slides.
I'm thinking maybe the full wall slide has changed things from the old days.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
map40
Posted: 01/19/23 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Reccomendations from the manufacturer will vary depending on several factors, but the most important is the structural integrity of the vehicle with the slides in vs the slides out.
Some RVs (mainly the ones with a lower cost) use the slide out closed as part of the structure. In these cases you need to level first and open the slide outs afterwards because the slides need to be part of the structure. The only issue is that when you open the slideouts the weight distribution will change and the RV might stress a little on one jack or even move if you are on soft ground.
The RVs in which the slideout wall is not part of the structure (a bus chassis for example) don't need the wall of the slideout to be in to maintain structure, so it is better to level the RV with the slides out to ensure great weight distribution.
I always believed that the safest bet is always to level first and open slideout afterwards, but me driving an Alfa, when the 4 feet slideout monster comes out you absolutelly can feel the RV change position...
Alfa SeeYa
Life rocks when your home rolls
wallynm
Los Alamos NM
Posted: 01/20/23 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
RTFM as in read the factory manual.I have seen slide and then level and level and then slide.
chompchomp wrote:
We’re now on our third Class A MH and the dealer insisted slides go out first . We have always leveled first. Any thoughts?
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Two Jayhawks
Lenexa Kansas
Posted: 01/23/23 09:20am Link  |  Quote  |  Print  |  Notify Moderator
My 2015 Dutch Star instructions says to leave aired up, don't level first, deploy slides. Same as Ro"n"Joe. I believe this instruction is there to protect the full wall slide. Yes it's backward to some but that's why you follow mfg's instructions. I'm 8 years in following Newmars instructions & no issues.
Bill & Kelli
2015 DSDP 4366 pulling a 21 JL Unlimited Sport
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
