RV.Net Open Roads Forum: Class A Motorhomes: Slides out or autolevelers down first?
 > Slides out or autolevelers down first?
chompchomp
Port Orange, Florida
Posted: 01/15/23 08:09am Link  |  Quote  |  Print  |  Notify Moderator
We’re now on our third Class A MH and the dealer insisted slides go out first . We have always leveled first. Any thoughts?
2008 Itasca Sunova 35J Motorhome
2003 Jeep Wrangler X Toad
1996 Key West 19CC Sportsman, 115 Yamaha
rk911
DuPage County
Posted: 01/15/23 08:26am Link  |  Quote  |  Print  |  Notify Moderator
what does the owner manual say? we always leveled first before deploying the slides.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
way2roll
Wilmington NC
Posted: 01/15/23 08:40am Link  |  Quote  |  Print  |  Notify Moderator
We have always leveled first on every RV we've owned. The logic; don't slides work better when the unit is level and risk damage if the frame is slightly twisted? RV frames are built to twist and flex during travel by design. Doesn't being level mitigate the risk of racking the slide out frame? Seems totally logical you want the frame box as square as possible before running it in and out.
Seen a guy once in a FW run his slides out first without jacks down. It was a full wall slide and the fridge was in it. The weight of the fridge needed the support of the jacks - and without the jacks the frame flexes which is fine when the slide is in, not so much when it's out. Well, heard a lot of screeching and cracking. He damaged a lot of trim and some flooring and it required 3 men to try and help him push his slide back in so he could deploy his jacks and do it over. Thankfully there wasn't any major damage to the rails or slide frame.
2023 FR Sunseeker 2400B MBS
jorbill2or
Full time
Posted: 01/15/23 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Manufacturers have different rules. You need to look at what yours says for your year. You can’t make a blanket statement. Mine says “ this “ isn’t an answer.
My Marquis is slides ( ride height) then level .. but that may not apply to yours.
Bill
phil-t
Ogdensburg, NY
Posted: 01/15/23 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Common sense (regardless of what the coach builder says) dictates being level before deploying slide(s). That's all there is to it! Slide mechanisms are not designed to operate when out of level. Read the slide out manual, or call the slide manufacturer.
2014 Allegro 36LA
Posted: 01/15/23 09:33am Link  |  Quote  |  Print  |  Notify Moderator
As others have said depends on the RV. I leveled first. And sometimes 3rd
If you are parked "uneven" the frame flexes and the slides can bind..
But some makers say Slid then level
And the weight of the slideouts can affect the leveling (Should not but can).
grldst
Dallas, GA
I have a Freightliner XC chassis with power gear leveling system. It says to deploy the slides before leveling or dumping the air.
It appears their logic is that with the chassis supported by the air bags is better. They must feel that the jacks will flex the frame when leveling.
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 01/15/23 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
The dealer may have read the owners manual. Could be a first. But do read the owners manual as if there will be a test, because there will be on some cold dark rainy night.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
Bruce Brown
Northern NY
Posted: 01/15/23 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
^^^ This.
Years ago we were having this discussion with friends of ours who owned a Monaco at the time.
The owners manuals came out and theirs clearly said slides out THEN level.
Our manual clearly says level FIRST.
To me it makes more sense to level first but I'm not the engineer who designed it. I'll listen to the guys who did.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
dodge guy
Bartlett IL
Posted: 01/15/23 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Always level first. Otherwise if off level the slides can and will go out uneven and may cause damage.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
