Bird Freak
Dallas Ga.
My buddy has a problem with his Dometic a/c unit. This is a older unit. It may run all day and then just shut's off and comes right back on and continues to do this. It acts like the power shuts off and comes right back. I replaced the thermostat because I didn't understand what he was telling me to start with and no change.
Any Idea's what will cause this?
edited 01/16/23 12:08pm by Bird Freak *
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
enblethen
Moses Lake, WA
Could be issue with the power if it is a low voltage thermostat. Low voltage control should have a transformer and could have an auto resetting circuit breaker.
make and model of original and replacement thermostat.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Coach-man
I agree it is a voltage issue! The thermostat operates on DC voltage which operates a relay. The relay turns on/off the A/C unit. Low voltage will let the relay release prematurely and then it try’s to turn back on. It could also be a faulty relay. Looks like you need a qualified A/C technician to check all the components.
pianotuna
Regina, SK, Canada
I am in a unit that does that. I don't think there is any power shedding--but that could be it too.
Regards, Don
Hondavalk
Toledo
i know with mine the unit will have a pause like when the blower automatically changes speeds. been doing that for the eleven years ive owned it. the hotter it is the more it cycles
enblethen
Moses Lake, WA
Get the model number of his Dometic A/C unit.
Bird Freak
Dallas Ga.
enblethen wrote: Get the model number of his Dometic A/C unit. He is 70 miles from me and can't get on the roof and has no paper work.
enblethen
Moses Lake, WA
What is the approximate age of the unit?
Should also have some information under the interior unit.
edited 01/17/23 09:42am by enblethen *
Bird Freak
Dallas Ga.
enblethen wrote: What is the approximate age of the unit?
Should also have some information under the interior unit. 2003
enblethen
Moses Lake, WA
That helps.
That age probably has a circuit board. could have a loose connecting on circuit board.
