jaycocamper62301
Illinois
I have a dometic 975 door awning that went mysteriously out of adjustment. I have been turning the screws for the last 4 hours and once i get the awning all the way closed and cycle it again it is out of adjustment. Is the awning junk? Is there a way to over ride the auto stop setscrew adjustment and just run it in and out with a remote with common sense? Is the set screws only one revolution or do you keep screwing and screwing ?
Serverly agitated
opnspaces
San Diego Ca
I've never had such a system. But from experience whenever something suddenly goes awry and the adjustment screws do exactly what you're describing. It's time to take a step back, take a breath and figure out what is actually going wrong to cause the adjustments to wander so much. Something is loose or a mounting point is rotting and not secured or ??? Take a careful look at it while in operation and you'll hopefully spot what is wrong that's causing this.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
dougrainer
Carrolton, Texas
Your manual. VERY small turn adjustments. Doug
https://epi.dometic.com/externalassets/d........MzkxNDQ4Mi4xLjEuMTY3MzkxNDQ4OS4wLjAuMA..
