RV.Net Open Roads Forum: Dinghy Towing: lighter weight four down toad?
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Vehicles
 > lighter weight four down toad?
obie311
Aux Arcs
Posted: 01/16/23 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I googled looking for a toad to use as a dinghy for a 3500 Sprinter Class C.
The recommendations were vehicles like Jeeps, F150 pickups, Chevy Colorado, Equinox.
That's heavier than I want. Aren't there some scooters like a Kia Soul or Honda CRV or HRv that'll flat tow? A Honda Fit or BMW Mini are a little too small.
The Honda Element seemed to be what I had in mind but they don't make them anymore.
* This post was edited 01/16/23 08:40pm by obie311 *
rk911
DuPage County
Posted: 01/16/23 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
what is your GVWR, GCWR, weigjt rating for your hitch and towbar?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
obie311
Aux Arcs
Posted: 01/16/23 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer hitch: 5,000-lb. drawbar/ 500-lb. maximum vertical tongue weight.
GCWR: 15,250 lbs.
GCVR: 11,030 lbs.
Don't have a tow bar. Waiting to see what toad I buy,
rk911
DuPage County
Posted: 01/16/23 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
the basic rule of thumb is that the max weight you can safely tow is the LESSER of the following:
- the difference between the GCWR and GVWR. both are published numbers by the RV mfg. if you can't find the GVWR you csn get a good approximation by adding the GAWR (gross axle weight ratings).
- the weight rating of the hitch
- the weight rating of the towbar.
is the 11,030 the GVWR of the MH? assuming it is then the maximum weight you can tow,is 4,220-lbs. and that assumes that your MH weighs no more than 11,030-lbs when fully loaded for travel. fully loaded includes everything in the MH...food, fuel, water, LP, clothes, supplies, food, people, etc. it also assumes that neither axle is overloaded...each axle has it's own weight ratings. a 5000-lb towbar would be fine and when flat towing there is negligible tongue weight (no significant downward pressure on the hitch). but the 11,030 is a weird figure. GVWR's are usually even numbers like 18,000, 24,000 or even 19,500-lbs.
obie311
Aux Arcs
Posted: 01/16/23 11:22pm Link  |  Quote  |  Print  |  Notify Moderator
Yes that's exactly what my calculations revealed. The published 11,030 is the figure I found from Lichtsinn RV.
A 2022 Honda CRV curb weight is ~3600 lbs. + 90 lbs for 15 gallons gas + ~40 lbs (strictly a guess) for towbar and bracket would give me a gross weight of toad vehicle of 3730. Well under the 4,220 lb. figure. I'm an old pilot so I'm used to figuring weight and balances.
Now, back to my original query. I'm looking for a four down toad in a certain size and weight parameter.
Any suggestions??
southernsky
Ponchatoula La.
Posted: 01/17/23 04:08am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2020 Ford Ranger 4X4.
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
wildtoad
Blythewood, SC
Posted: 01/17/23 04:25am Link  |  Quote  |  Print  |  Notify Moderator
A good used Chevy Sonic (auto or manual) or Spark (manual) but the latter may be too small.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
JRscooby
Indepmo
Posted: 01/17/23 04:38am Link  |  Quote  |  Print  |  Notify Moderator
GCWR: 15,250 lbs.
GCVR: 11,030 lbs.
I'm assuming this should read GCVWR 15250 and GVWR 11030, for the combination weight, and vehicle by itself.
If this is true, the first step is weigh the van, loaded ready to camp. If you are at the vehicle's rating, then 4220 is max, and that includes the bar. But if you are below max, say 10250, you have 5000 for toad.
JoeH
Apollo Beach,FL
Posted: 01/17/23 05:55am Link  |  Quote  |  Print  |  Notify Moderator
I've towed a Tracker and a Ranger.... Tracker was about 2200 lbs. Fun car !
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
routeforty
ohio
Posted: 01/17/23 06:06am Link  |  Quote  |  Print  |  Notify Moderator
We tow a 2021 chevy spark manual transmission 4 down behind our class c. A little over2k lbs. And seriously if it were not for the rear camera I would not know it was back there. Had the base plate put on at etrailer. The car is small but gets 40mpg and works perfect for the 2 of us.
2018 coachmen leprechaun class c 2008 KZ spree 260FL
