mkirsch
Rochester, NY
Here in NY state there is the concept of "homemade" trailers, which allows you to register and title pretty much any trailer by calling it homemade.
TyrellMoris
BB_TX wrote: First thing is look for water leaks. If it has water leaks, then you may find significant rot of any wood members. It doesn't take long once leaks start. That might determine if you proceed, or just scrap it. May be just the picture angles, but the structure looks somewhat twisted.
The twist is probably from the picture but I was inside of it today and unfortunately, I believe that this is past recovery and time to scrap it. There must have been some leaks and I took some pics of the water damage. The front of the trailer, roof, and floor are all squishy to the point where I can drive a screwdriver right through it I if wanted to. And the roof is sagging and it's all black and moist underneath. Also concerned about black mold as well.
![[image]](https://i.imgur.com/bVGO60p.jpg)
![[image]](https://i.imgur.com/LV7HfLQ.jpg)
![[image]](https://i.imgur.com/ZCQPUzc.jpg)
MOD'S EDIT: Fixed the photo size so the pics won't blow up the page.
edited 01/19/23 08:58am by an administrator/moderator *
Boon Docker
Looks like everything above the frame needs to be scrapped.
ralph day
Ontario Canada
looks like a possible utility flat bed trailer project...if the frame hasn't rusted away.
TravelinDog
Nevada
That trailer is definitely not worth the time and money even if it is free.
Just say no to the payload police ">
bucky
Raleigh metro
The trailer is not worth saving. Turn it into a utility trailer and be done with it.
Puma 30RKSS
4x4van
California
"Some" leaks is pretty much an understatement!
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
TXiceman
Bryan, TX
As you see, it is a Citation brand, probably made by Thor. From the looks of it, this trailer has sat a long time with no care or maintenance. It is most likely a wood frame trailer and there are obvious signs of water intrusion. This means rotten wood.
Personally, I would not invest the time or money to do much of a restoration. It will be a money pit.
Krn
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
ralph day
Ontario Canada
Check out Jenniesgarage videos regarding a complete rebuild of a Shasta trailer. The frame and aluminum siding were all that were salvaged, so a complete rebuild.
https://www.youtube.com/@jenniesgarage/search?query=shasta
They are a fun couple to watch;.
