RV.Net Open Roads Forum: Fifth-Wheels: Generator question
 > Generator question
Page of 6
padredw
East Texas
Posted: 01/20/23 08:15am Link  |  Quote  |  Print  |  Notify Moderator
If your RV has an adequate hitch -and- if your electrical inlet is nearby, you might consider my solution.
[image] My link (link looks the same to me)
[image] Bud's link (copied from his post below)
I give up. I can't get this image to display.
Note the input at the rear of the trailer. Note the input cord on the tray. I can run the 15K AC while driving down the road. I only do so in the heat of summer to cool off the trailer about half hour before arrival at campsite. The generator is a Honda 3000. It provides 30 AMP power to every outlet in the trailer, with the usual constraints of a 30 amp supply.
* This post was edited 01/20/23 11:45am by padredw *
enblethen
Moses Lake, WA
Posted: 01/20/23 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Padre your link
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
padredw
East Texas
Posted: 01/20/23 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Bud, that works. Wonder why it works in your post and never did in mine? I tried several variations; none worked. But this works fine and illustrates my generator.
I will go on to say that I have a 3000 watt inverter which allows me to plug in my power cable just as I would to a campground pedestal and into the same power inlet as the generator or from the campground power. Everything is powered, not that I would try to run everything from the batteries.
enblethen
Moses Lake, WA
Posted: 01/20/23 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Padredw:
You are not biting your tongue! Maybe you didn't talk right to it!
Could be something in your settings.
2oldman
NM
Posted: 01/20/23 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
The problem was not posting a link, it was displaying an image. I don't see an image.
enblethen
Moses Lake, WA
Posted: 01/20/23 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Right click on image and open in new tab
2oldman
NM
Posted: 01/20/23 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
That doesn't work. I thought we were talking about displaying an image without any clicking.
Lantley
Ellicott City, Maryland
Posted: 01/20/23 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
For the record a 3000 watt genset does not have the same power as a 30 amp pedestal. A pedestal has 120 volts x 30 amps = 3600 watts vs. 3000 for the genset.
Not a huge difference and not a deal breaker, but a not quite equal either.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Cptnvideo
Arizona - most of the time
Posted: 01/20/23 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
I've never heard of a pin box mount for a generator. So now I am very curious. Does anybody have a link or more info?
For the OP, I have a portable 3500 watt inverter generator (Harbor Freight). I've used it twice due to all the solar I have. And I have a residential fridge. I can also run an A/C unit off the batteries. And frequently boondock or dry camp. But my solar setup would cost more than a built in generator. I would also prefer to run a portable on gas rather than a built in on propane. Just my preference.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
Lantley
Posted: 01/20/23 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
pin box mounted genset
Moderator edit to re-size image to forum recommended limit of 640px maximum width.
* This post was edited 01/21/23 09:14am by an administrator/moderator *
Page of 6
