Cptnvideo
Arizona - most of the time
Thanks, Lantley. I don't see an issue with that with my 8' bed. Who sells them? Or is it home made?
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 5 206AH LiFePo4 batteries for 1030 ah
Lantley
Ellicott City, Maryland
I believe they are generally home made
edited 01/21/23 09:13am by an administrator/moderator *
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Learjet
Louisiana
muffler is close to front cap ??
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
Veebyes
Lantley wrote: pin box mounted genset
![[image]](https://www.forestriverforums.com/forums/attachment.php?attachmentid=179596&d=1531606803)
Your neighbours must love you with that thing. I would not want to be within 100yds of it. Don't care where it is mounted.
Moderator edit to re-size image to forum recommended limit of 640px maximum width.
edited 01/21/23 09:12am by an administrator/moderator *
2007 Alpenlite 34RLR
Lantley
The photo I posted of the pin box mount is not my rig. I posted a generic photo I found on the internet to give the OP an idea of what a pin Box mount looked like.
But as some have pointed out all portables are not created equal.
Potables come in all sizes, weights, noise levels and price points.
Choosing the right RV portable generator is all part of the process.
Cptnvideo
Another option that I am looking at is a generator slide out tray.
I could put my portable in the compartment intended for a generator, out of sight and locked up. Then slide out the tray to run (for ventilation purposes).
Learjet
Louisiana
I ordered my Pinnacle with the Onan 5500 propane and 3 x 40 lbs. tanks. Love it and works perfect what I needed. That 5500 gen is very quite and smooth.
Campinfan
Washtenaw County, Michigan
I was looking at a 3800 watt (peak) and I think it is a 3000 or up to 3400 (cannot recall right at this moment)..Are the Harbor Freight ones quiet? I have heard mixed things about them (the generators) and some of their stuff is not the highest quality but I still buy a few things from them.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Campinfan
You folks are giving me great ideas and things to think about. Thank you so much.I am just glad this is not a purchase I have to make real soon, lots of things to consider.
valhalla360
No paticular place.
Lantley wrote: For the record a 3000 watt genset does not have the same power as a 30 amp pedestal. A pedestal has 120 volts x 30 amps = 3600 watts vs. 3000 for the genset.
Not a huge difference and not a deal breaker, but a not quite equal either.
Depends how the generator is spec'd...and that's all over the place.
Had a Yamaha 2400 that could spike to over 3000w for startup loads. The aircon typically pulled 1200-1500w, so it worked fine with enough for other light loads (fridge, tv, lights, etc...)
The tried and true Honda 2000w units peak at 2000w with a continuous output of 1600w.
A 30amp campground pedestal is only rated for 24amps (2800w) continuous load.
In terms of generators, 3000w is typically suggested as the minimum size where it can reliably kick over the air/con compressor without modifications to the air/con unit and you aren't running the generator at max rating all the time.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
