RV.Net Open Roads Forum: Truck Campers: Help - jacks are draining my batteries
 > Help - jacks are draining my batteries
Page of 6
Dupa
Colorado
Posted: 01/19/23 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
ssthrd wrote:
I leave both my camper and my trailer plugged in to my running truck (my cords are plenty long enough) until I get the thing where I want it. Then unplug and drive away............ No draw on the batteries at all as far as I can tell.
Maybe your genny isn't large enough.
I've got two of the Honda 2000 gens (they are new and in good running cond.), so that should be plenty big enough?
Krusty
Calgary, Alberta,Canada
Posted: 01/19/23 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Get one of those booster packs and connect it to your batteries while you are using the jacks. Or disconnect them from the batteries completely and just use the booster pack until you have the camper where you want it.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
enblethen
Moses Lake, WA
Posted: 01/19/23 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
The converter when powered via shore power or genset should feed the jacks adding to the battery power.
Something is not right in your campers wiring!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
2oldman
NM
Posted: 01/19/23 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Dupa wrote:
2oldman wrote:
Run the generator while removing the camper.
That was my first thought as well but, unfortunately, the jacks only draw from the battery. So whether I am connected to the truck, gens or shore power while loading/unloading, the jacks discharge the batteries much faster than the truck/gen/shore can replenish.
Still that would be better than not using the gen, right?
2oldman
NM
Posted: 01/19/23 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, sounds like your converter isn't big enough.
mellow
Salisbury, MD
Posted: 01/19/23 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a converter issue, generator outputs AC, when running the converter should convert to 12v for charging batteries, I can have almost dead batteries and as long as I get the generator started I can use my jacks without issue and I have a heavy camper.
I would put a voltmeter on your batteries and see what they are doing with the genny on and operating the jacks.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
3 tons
NV.
Posted: 01/19/23 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve periodically lifted and lowered my #4400 (dry) Eagle Cap camper off and on for 13 years, mostly using two Interstate or Costco golf cart batteries (but since having switched to lithium [emoticon] )…I’ve never had the problem your having EXCEPT when a cell or two was getting weak on the golf cart batteries, in which case even the slideout struggled…The fix was to replace the wet-cell batteries…BTW, the batteries showed no other indication of weakness ‘whatsoever’!!
Time to get new batteries…
3 tons
ICamel
Oregon
Posted: 01/19/23 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the 12v DC charging cord for your generator, try hooking it directly to your camper batteries while running your generator rather than running it through your converter when raising or lowering your camper?
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
3 tons
NV.
Posted: 01/19/23 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, the 12v dc current output from my honda 2200i generator falls far short of the current output from my OEM 45a Progressive Dynamics converter charger…Either way, the owners manual belonging to my truck camper specifies not to operate jacks from any source other than the batteries…
3 tons
Posted: 01/20/23 12:55am Link  |  Quote  |  Print  |  Notify Moderator
But it does no harm to be pumping juice into the batteries while drawing from them. Kinda how it works.
Page of 6
