Cummins12V98
on the road
FishOnOne wrote: Plus Ram is way overdue to update their HD trucks to the new body style.
You mean like ford on the last LONG run???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
MFL wrote: 4x4ord wrote: ^^^ It’s not posted as fact anywhere as far as I know….. it’s just me thinking it’s pretty tough to compete in a 500 HP/10 speed market with 420 ponies and 6 gears.
"the 2023 Ram is apt to take a big hit in depreciation when the ‘24 comes out with 8 gears and 480 horsepower / 1200 lbft of torque."
You will lose credibility by making these type statements. If you would have said guessing, or if, in that remark, you wouldn't be providing false info.
Yes, you did clear that up, after being confronted.
Jerry
OUCH!!! That even hurt me Jerry!!! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
He is actually the one that said the 6 x 6 is just fine and would not make much difference with more gears.
As mentioned WHY in the HE!! change when you have combo's that do the job reliably.
I will repeat, I tow way more weight than most anyone here at 35k combined West Coast and have ZERO reason to want more gears or power. I have owned both trans and I love them both.
Cummins12V98
on the road
"And noise level by running lower RPMs."
What NOISE LEVELS??? Never heard the newer RAM's called noisy.
MFL
Midwest
Cummins12V98 wrote: MFL wrote: 4x4ord wrote: ^^^ It’s not posted as fact anywhere as far as I know….. it’s just me thinking it’s pretty tough to compete in a 500 HP/10 speed market with 420 ponies and 6 gears.
Jerry
Harsh...not intended. Just a tip for a respected member, that many trust to be stating facts, when in this case it wasn't. Good that you asked him!
My opinion...I agree, with the Ram not NEEDING more than a stout 6-speed. I do think similar to others opinions, that since technology continues to advance for Ford/GM, at some point Ram will follow. Right/wrong, it will be considered upgrading the drivetrain and body/frame/styling.![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Jerry
FishOnOne
The Great State of Texas
Jerry
The one you felt inclined to install a after market oil pan or the one on the shop floor? I'm confused... ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
The 68RFE
![[image]](https://i.imgur.com/aE8Re2ml.jpg)
The almighty Aisin that doesn't break
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
blt2ski
Kirkland, Wa
Yes Fish, he had a trans on the floor. Worked fine!. But had an oil leak in gasket. Took in to fix before warranty went out. Mechanically, worked fine. Both of you are stretching the truth some. IMHO, both of you are also false in comment. Get over it.
Marty
2014 Chevy 1500 Dual cab 4x4
TurnThePage
North ID
blt2ski wrote: Yes Fish, he had a trans on the floor. Worked fine!. But had an oil leak in gasket. Took in to fix before warranty went out. Mechanically, worked fine. Both of you are stretching the truth some. IMHO, both of you are also false in comment. Get over it.
Marty
LIKE!
2015 Ram 1500
2004 Pioneer 18T6
Cummins12V98
on the road
FishOnOne wrote: Cummins12V98 wrote: MFL wrote: 4x4ord wrote: ^^^ It’s not posted as fact anywhere as far as I know….. it’s just me thinking it’s pretty tough to compete in a 500 HP/10 speed market with 420 ponies and 6 gears.
Jerry
The 68RFE
![[image]](https://i.imgur.com/zuGMIpQl.jpg)
You must have a catalog on everyone or just me???
Both were great as I have mentioned many times. Not sure what the big deal is about adding a deeper pan???? The point of the pic was at 65k with way over 50k on the AMZ/OIL ATF the pan was near spotless towing 30k combined most of the miles. ONLY reason I removed the pan was I traded the 11 on the 15 and sold the pan.
You also know the reason the AISIN was replaced it had NOTHING to do with the trans at all. It had minor weeping where the case meets so I had it repaired under warranty. The Tech is the GOD in the Valley when it comes to transmissions. He had only replaced two AISIN's under warranty up to then because of casting issues. He did the separation with the trans in place and the proper way was to remove and stand on TQ converter end. Obscure Technical Bulletin later showed this. NOT the fault of the transmission!!!
So I have to ask what was the point of you posting the pics?????????
Cummins12V98
on the road
Marty
I hope I am not one of "Both"
FishOnOne
Looks like a loaded Denali DRW 2 wheel drive tops out over $100k.
Link
