RV.Net Open Roads Forum: Fuel tank leaks when we fill it
 > Fuel tank leaks when we fill it
CalebT
Phoenix, AZ, USA
Posted: 01/23/23 10:35am Link  |  Quote  |  Print  |  Notify Moderator
So this may be a stupid question but we are in Arizona during busy season so we are having a hard time finding anyone to work on this. So the issue is that our fuel sensor isn't reading correctly when we fill it it stays at half full then goes up as we drive it a little ways then starts to act normal. So when we go to fill it if we let it fill completely I think it can't tell that it is full and we end up overfilling the tank. It drips from the top around the side and down to the ground only when we completely fill it. So we are fairly certain this is the issue for my peace of mind I have been trying to find someone who would just take the fuel tank down and check if there is a crack on it at the top. Anyway my stupid question is ..is it safe to light our pilot for our furnace and water heater. We have been at a campground for almost a week but it has been really cold at night in Arizona last night there was a freeze warning.
pianotuna
Regina, SK, Canada
Posted: 01/23/23 10:42am Link  |  Quote  |  Print  |  Notify Moderator
If it is diesel there is little chance of ignition.
You could fill the tank until the first click off happens.
Regards, Don
MarkTwain
Northern, Ca. , USA
Posted: 01/23/23 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Look for a business that installs after market fuel tanks i.e. "Transfer Flow"
Bruce Brown
Northern NY
Posted: 01/23/23 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like possibly a vent line clamp might not be tight. Take a look at the filler neck and make sure everything is tight. If possible do the same thing at the tank too.
The "stop filling at the first click" suggestion is good too.
BTW, gas or diesel?
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
dougrainer
Carrolton, Texas
Posted: 01/23/23 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
You just joined. ALWAYS post Year,Brand/Model of RV and Diesel or Gas. This helps to get you good answers. There is nothing really on a diesel to prevent overfilling. The Fuel Gauge has nothing to do with filling. You need to observe if you get a small leak when filling and not just when you reach close to full. It may be as simple as a fill hose loose or cracked from age(where the year info helps on answers). Some tanks and gauges the tank does NOT have to be dropped(diesel) if you have a Monaco or Holiday Rambler, to check hoses and fuel gauge sending unit. Doug
2oldman
NM
Posted: 01/23/23 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
You have an old enough rig that you have pilot lights?
Horsedoc
Dixie --- N. Georgia
Posted: 01/23/23 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Steel or plastic tank? I might look at the synthetic hose between the filler cap and tank - crack or leak? vent with a loose connection into tank? Leak where the wires go come from the tank float to the outside?
Could be several places I guess.
nickthehunter
Southgate, MI
Posted: 01/24/23 06:58am Link  |  Quote  |  Print  |  Notify Moderator
If the fuel gauge is acting up in simultaneously with a drip/leak it's sounds to me to be more likely a fuel pump/gauge assembly problem. Dropping the tank is the likely next step.
IB853347201
Eastern Ontario
Posted: 01/24/23 07:40am Link  |  Quote  |  Print  |  Notify Moderator
X2
2010 Suncruiser
2oldman
NM
Posted: 01/24/23 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
drive by?
