RV.Net Open Roads Forum: Dinghy Towing: Dinghy charging from MH
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Dinghy charging from MH
camperdave
northern, California
Posted: 02/01/23 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Another option could be swapping your CRV taillights to LED. Then you wouldn't have to worry about them draining the battery.
2004 Fleetwood Tioga 29v
willald
NC
Posted: 02/02/23 07:33am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
the 4 wire for the tail lights is sort of hard wired in. I ran it under the sill plate, through the frame and into the tail light housing. While I could remove all that, it's really neat and tidy the way it is and I can hide the harness in a nice spot in the lower grill.
I'm not thinking you'd have to remove all of that, to go to a 6 round connector and a charge line.
Only place you'd change things and change the wiring, is at the very front of the car. Basically, you'd just install a 6 round connector somewhere on front of the vehicle, and take those same 4 wires you presently have connected into a 4 flat connector up front, and instead connect them into the appropriate pins on the 6 round connector (and, of course, do away with the 4 flat connector on the front). While you are doing this, you would also route one wire from + terminal of the battery to the appropriate pin on the 6 round connector as well, for your charge line.
Then, you'd just install a 6 round connector on back of Motorhome, and wire it up appropriately. You could make an adapter like I did, that on one end wires directly into the 6 round connector, other end plugs into your Motorhome's existing 7 pin connector.
This way, you'd be using a standard, very easy to find when needed, 6 pin wire from Motorhome to the towed vehicle. If it ever wears out or gets damaged, getting a replacement would be quick and easy, as they are pretty popular and frequently on the shelf at RV dealers.
What's the issue with adding one wire with a bullet to the appropriate spot in the 6 round adapter and just tie it to the 4wire harness? Aesthetically it will be the same. It's just one extra wire that can be tied and hidden with the 4.
No real issue, you could do it that way and it would work fine. And, ultimately its your rig and you can do it the way you want.
However, it would mean you'd have a very specific, custom wire setup going between your Motorhome and your towed vehicle. It would also mean, like I said before, that now you have two wires and 4 connectors to maintain and keep up with instead of just 1 wire and 2 connectors. Not to mention, hitching up and unhitching would be a little more complicated, because now you have two wires/connectors to connect and disconnect each time vs. just one if you did it all in a 6 round like I was talking about.
Your rig, you do it the way you want, is the bottom line. I certainly take no offense if you chose to do it this way. Long as you're happy with it and it works, I wouldn't worry about it. [emoticon]
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
