RV.Net Open Roads Forum: Fifth-Wheels: VanleighRe-sealing the nose of a fifth wheel
 > VanleighRe-sealing the nose of a fifth wheel
tourusa
Ft Lauderdale
Posted: 01/24/23 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all
I have a 2020 vanleigh and would like to reseal the nose without getting on the roof, anyone got a quick step guide tips.
* This post was edited 02/11/23 07:12am by tourusa *
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
tourusa
Ft Lauderdale
Posted: 01/24/23 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
tourusa
Ft Lauderdale
Posted: 01/24/23 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
MFL
Midwest
Posted: 01/24/23 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
To check the front cap roof top, someone has to get on the roof, and inspect very closely. Most newer roofs are rounded, so even if the leak is near the driver side, it could originate from center of roof.
Another possible source, for a leak, in that area, would be the clearance lights. If water sets in the cutout for them, during hard rain, it could reach the hole the wires come through, behind the lights.
If you are not comfortable getting on the roof, I'd suggest having someone else check for you.
Jerry
tourusa
Ft Lauderdale
Posted: 01/25/23 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Clearance lights are sunken types, I was thinking the corners near the gutter to tease first
TXiceman
Bryan, TX
Posted: 01/25/23 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, but to really do any good on trying to get the leak fixed, someone needs to get up on top and check the roof to cap seal as the clearance lights. Water will run downhill to the lowest point to become apparent. So, your leak can be some distance away from the indication.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
schlep1967
Harrisburg, PA
Posted: 01/25/23 09:58am Link  |  Quote  |  Print  |  Notify Moderator
You will need to get somebody up there to look at where the edge of that front cap meets the roof. Look at your first picture. The front cap is higher than the roof. Probably about 1/2 of an inch. That will be sealed with self leveling caulking. If something wasn't done completely correct at the factory, you may need to remove some of the old and apply new self level or eternabond tape. The roof slopes forward into that seam. The water obviously follows the slope to the "dam" created by the raised front cap.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
C Schomer
Pueblo West, Co.
Posted: 02/10/23 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I did my front and rear seams from step and extension ladders. I removed the gutter spouts and pulled back the side trim a little bit so I could find any problems and fix/seal things right. Have some eternabond tape and caulk, NOT the self-leveling, ready. I also increased the dia. and length of the screws, so they gripped better. Craig
tourusa
Ft Lauderdale
Posted: 02/11/23 06:33am Link  |  Quote  |  Print  |  Notify Moderator
Hi Craig how is the eterna bond tape to install did you use lap seal over it
* This post was edited 02/11/23 06:59am by tourusa *
deltabravo
Spokane, WA
Posted: 02/11/23 08:30am Link  |  Quote  |  Print  |  Notify Moderator
DITTO.
You can't reseal the nose cap / roof seam until you get on the roof.
