RV.Net Open Roads Forum: Fifth-Wheels: VanleighRe-sealing the nose of a fifth wheel
 > VanleighRe-sealing the nose of a fifth wheel
tourusa
Ft Lauderdale
Posted: 02/11/23 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Will do , if putting eterna bond on the existing strip and sealant once cleaned do I need to put lap seal over that, this is a 2020 model
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
C Schomer
Pueblo West, Co.
Posted: 02/15/23 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Eterna bond recommends a coating over it. I don't like the crappy way the mfgrs seal things... by caulking OVER edges AFTER things are screwed down. I removed all screws and cleaned under the overlaps, caulked, and then shot the screws back in. Then eternabond and roof coating over everything on the roof.
It took the first 5 months of 2019 and I did ALL the other lap joint on my 5er, windows, roof lights and fans and bottom skirting, by cleaning and caulking under every joint. I dare anything to leak! Craig
tourusa
Ft Lauderdale
Posted: 02/15/23 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Craig will check the roof and front seal then finally eternabond
