RV.Net Open Roads Forum: General RVing Issues: Dometic ceiling fan inoperable
 > Dometic ceiling fan inoperable
tourusa
Ft Lauderdale
Posted: 01/25/23 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Morning all I have a dometic ceiling fan which comes on when the vent is open and has 0-3 speeds, I checked the fuse which is good and it’s still not working
Any ideas
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
tourusa
Ft Lauderdale
Posted: 01/25/23 08:51am Link  |  Quote  |  Print  |  Notify Moderator
2oldman
NM
Posted: 01/25/23 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I don't have a clue, but my fan hasn't been that clean in years!
ronharmless
The far side
Posted: 01/25/23 10:13am Link  |  Quote  |  Print  |  Notify Moderator
If the fan only can come on when the vent cover is open, then there is a switch in the vent cover. Use a volt meter and check the vent cover switch. You can also jump/bypass the switch to see if it is malfunctioning. You can jump the 0 - 3 switch also to see if it is malfunctioning.
MFL
Midwest
Posted: 01/25/23 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Well, your not much help...but I'll help you! You need to change your maid service!
Agree with ron above.
Jerry
bob_nestor
murphy
Posted: 01/25/23 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
The switch is just a plunger and you can try tugging on the plunger to see if the fan comes on. When the cover closes it pushes the plunger down which disables the power to the fan. The plunger switch tends to get corroded or stuck with gunk, especially when camped near the seashore. If it is the plunger, a little WD-40 will clean it up and solve the problems.
Posted: 01/25/23 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
There are a few parts that are suspect
First is there 12 volts to the fan assembly (Use a test light not a volt meter please) (Bright is good, Dim is not)
The 4 position switch (OFF LOW MED HIGH)
The Thermostat
The Lid Switch
You can bypass the lid switch and the T-Stat to test.
Not sure how the 4-pos is wired. so not sure how to bypass.
tourusa
Ft Lauderdale
Posted: 01/25/23 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
The plunger switch can I get to it from underneath
slider45
GA
Posted: 02/01/23 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
You sir are surely getting a quality service!
MFL
Midwest
Posted: 02/02/23 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Absolutely...I am fortunate to live and camp, with a Domestic Engineer!
To the OP...did you get your fan going?
