RV.Net Open Roads Forum: Tech Issues: yet another door look bites the dust
 > yet another door look bites the dust
pianotuna
Regina, SK, Canada
Posted: 01/26/23 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Does anyone have a source for a trimark all steel lock?
It's a good thing I'm in a class C. Being locked in is not much fun.
Regards, Don
JimK-NY
NY
Posted: 01/26/23 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Since you are in a class C, it doesn't matter but you should be able to unscrew and remove the lock from inside the RV. When mine broke, I had no problem finding a replacement at an RV parts store. I never saw an all steel model. Mine has plastic parts on the inside.
pianotuna
Regina, SK, Canada
Posted: 01/26/23 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply.
Except that the screen door covers one of the screws. What a 'smart' design.
opnspaces
San Diego Ca
Posted: 01/26/23 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Can you sneak in a right angle screw driver?
Harbor Freight
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
ronharmless
The far side
Clicky
RLS7201
Posted: 01/26/23 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
ronharmless wrote:
Clicky
Good idea. But a screw driver bit and a 1/4" wrench fits in smaller areas.
Richard
95 Bounder 32H F53
460/528 stroker
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
pianotuna
Regina, SK, Canada
Posted: 01/26/23 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
As we get to -40 I do not want an electric lock of any kind.
Ed_Gee
Central Oregon coast
Posted: 01/26/23 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I wish you had specified what Trimark lock. If its the T507 common to so many class C RVs, like mine, Did your latch bolt break? Its cheap pot metal. There's a guy who sells repair kit, easy to do, with a beautifully crafted stainless steel latch bolt replacement. I can vouch for this.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Gjac
Milford, CT
Posted: 01/26/23 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have replaced mine twice over the years when they broke and the third time, I made a steel backing plate to join the two pieces of the zinc alloy striker bar that broke. It has held up well. Someone posted on here a while back about a new lock that he thought was steel but could not verify that it was. This alloy which some call pot metal is brittle and soft, it is cast and not forged or drawn like steel making it much weaker. You need to take it part to see what is actually broken. It could also be the plastic cam inside that moves the sticker bar.
IAMICHABOD
Sunny So Cal
Posted: 01/26/23 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I remembered that repair kit,got it saved somewhere..Ahh here it is.
https://www.latchfix.com/
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
