RV.Net Open Roads Forum: Class A Motorhomes: Tiffin Sealant Question
 > Tiffin Sealant Question
jaycocamper62301
Illinois
Posted: 01/26/23 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
What type of sealant to use on the roof of our 2011 Tiffin Phaeton? It has the fiberglass gelcoat roof. There are places where i want to touch up/add to the factory sealant. The second project is installing a Starlink Mobile roof top antenna. Any help getting the right stuff would be appreciated. I saw a video not to use Dicor but instead use Nuflex 311???
Bruce Brown
Northern NY
Posted: 01/27/23 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Did Nuflex put out the video?
Just wondering as Dicor has always been good.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
jaycocamper62301
Illinois
Posted: 01/27/23 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
No a RV roof inspector did. Since over 100 people read this and no positive responses i have taken the time to research. If i would have used dicor it would have been a waste of time and money.
Tom/Barb
Oak Harbor, Wa
Posted: 01/27/23 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
I've had good results with Flexseal . be certain it's clean before you apply.
way2roll
Wilmington NC
Posted: 01/28/23 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Why is Dicor a waste of time and money? It's probably the widest accepted and used rv caulk on the market.
2023 FR Sunseeker 2400B MBS
Bruce Brown
Northern NY
Posted: 01/29/23 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I'd like to know why as well. Obviously the OP has learned something we do not know. Seriously, please let us know what you found out!
jaycocamper62301
Illinois
Posted: 01/29/23 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
You cannot put Dicor on top of NuFlex311 or CSL515. You gotta know what the manufacturer used. Different chemistry can be antagonistic
Bruce Brown
Northern NY
Posted: 01/29/23 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
If we knew NuFlex was currently there we all could have given a better answer. [emoticon]
So Dicor isn't a bad sealant, just not compatible with NuFlex.
Thanks for the info.
wjschill
Posted: 01/31/23 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Tiffin uses a silicone base sealant.
Dicor will not stick to silicone.
Watch AZ Expert on You-Tube. he covers this many times, by showing how the Dicor fails to seal over silicone.
Good Luck.
Skip
KillingTime
