brianseay1
Bridgeport, Ala USA
I just bought a jeep wrangler that has the Roadmaster baseplate model #521448-5 on it. I have been trying to figure out which tow bar will match to this specific base plate. I am going to have to buy the arms for it, but it already has the wiring harness installed. trying to figure out which power cord goes with it as well. Hoping some of you will have this setup and can point me in the right direction. Thanks for any help !!!
Brian & Neena & B.G.
B.G. 2014 Goldendoodle
2007 Coachmen Cross Country 389DS
300 HP Cummins Turbo Charged
03 Sahara Jeep Wrangler & 05 Harley Davidson Ultra Classic
2014 800 RZR4
Roll Tide Roll
StarkNaked
West Seattle, WA
Call Roadmaster customer service. They have been able to answer every question I have ever throw at them.
Roadmaster, Inc.
6110 NE 127th Ave.
Vancouver, WA 98682
Toll-free: 1-800-669-9690
Local calls: 1-360-896-0407
Fax: 360-735-9300
enblethen
Moses Lake, WA
Roadmaster Falcon towbar
Adapters are available for other bars.
etrailer
I copied this from etrailer
"Note: Roadmaster direct-connect base plates will only work with Roadmaster tow bars that slide into a trailer hitch, such as the Sterling, Blackhawk, Blackhawk 2, Falcon, or Falcon 2. These base plates will not work with tow bars that require a hitch ball."
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CA Traveler
The Western States
What towbar do you have? Do you really need to replace the arms? If so consider a new tow bar for your setup.
You may/may not find a power cord that is plug and play as you may need wiring modifications to match. ie 1 bulb/filament for turn brake vs 2 and charge line, etc. Recommend 6 wire cord, 4 for lights and 1 charge line, ground and charge wires are larger gauge. You might need something else depending upon the toad aux brake.
2014 Grand Cherokee Overland
Bob
BarneyS
S.E. Lower Michigan
Moved to Dinghy Towing forum from Towing.
Barney
brianseay1
Bridgeport, Ala USA
StarkNaked wrote: Call Roadmaster customer service. They have been able to answer every question I have ever throw at them.
Roadmaster, Inc.
6110 NE 127th Ave.
Vancouver, WA 98682
Fax: 360-735-9300
looks like this may be my best option, thanks for the feedback
enblethen
Moses Lake, WA
When you say arms, do you mean the towbar or the portion you insert it to the fixed portion of the baseplate?
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Yes, call Roadmaster tomorrow morning.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
brianseay1
Bridgeport, Ala USA
The previous owner called me and gave me the info I was needing. He told me the exact setup he used, do now I know exactly what I need to get. Thanks for the help everyone!!!!
