RV.Net Open Roads Forum: Class A Motorhomes: Dipping my fuel tank
 > Dipping my fuel tank
David0725
Posted: 01/29/23 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Found my problem getting full to my generator. Bad fuel line. I'm lower then a 1/4 tank of fuel so I think it's a good time. Has anyone ever pulled the tank if so what im I getting in to? Pros and cons
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
TechWriter
Part-Timing Again
Posted: 01/29/23 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in the same boat, but I'm having a local shop do the work as they've done it before.
The shop uses 4 jacks to slowly lower the tank -- even if it's full. But remember that diesel weights 7 pounds per gallon.
Good luck.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
JRscooby
Indepmo
Posted: 01/29/23 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Never on a MH, but have dropped more than a few tanks. Can't imagine the need for 4 jacks on tank, but I have a plate I can replace the load pad on floor jack.
Once I get a large tank (over about 50 gallons) down I pump it MT, just to ease control going back in. (Really prefer tank be near MT coming out, put often the neck will not allow)
One thing you need to watch is be sure you have vehicle high enough to get tank out, or that you can do what you need under the vehicle.
oldave
Tx
Posted: 01/29/23 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I think it's going to matter a great deal what coach you're talking about.
Are you sure you can't get to the fuel line/top of the tank?
Have you tried tightening the hose clamps?
Brian in Michigan
S.E. Mi.
Posted: 01/29/23 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have dropped my tank a couple of times. It's a 60 gallon tank. One of the times it was half full. I used a harbor freight 1000lb hydraulic table. I removed the handle so it was to lay flat to get it underneath the motorhome. I was able to jack it up to the tank and support it while I unbolted the straps and bolts. I dropped it slightly so as to remove the hoses. Then I was able to drop it all of the way down and roll it out from underneath.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
larry cad
ohio
Posted: 01/29/23 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe I misunderstood, but the generator fuel line is not supposed to empty the tank, but rather, it only goes down to 1/4 full. This is to prevent the tank from emptying which would prevent the DP from running (to get more)!
Our Travel Blog
Rick Jay
Greater Springfield area, MA
Posted: 01/29/23 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I believe my tank is 75 or 80 gallons (gasoline). I used the same hydraulic table to drop the tank. One of the spot welds used to hold a tank baffle developed a leak. After playing around with sealers which would only work for a couple of months at a time, I decided to have the leaking spot patched with a weld. My cousin did the welding for no cost. No problems with fuel leaks since! (Yes, we know gas tanks are a challenge to weld safely and many won't attempt it. My cousin is a master at it and knows how to do it safely.)
I figured that hydraulic table was worth the price over paying someone else to drop & clean the tank and then weld it. It allowed me to safely lower the tank in a controlled manner. My tank is fairly long, and even with just a little liquid in it, the shift of weight as it tilts makes it a handful to deal with. The large platform on the hydraulic table made it a fairly straight forward one-man operation.
Now, I often use it as a portable, rolling table, so it still gets some use.
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
Fulltimers
Anywhere, USA
Posted: 01/29/23 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
If you are lower that 1/4 tank, that's your problem. The generator will not pick up fuel from a tank that is lower than 1/4.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
Brian in Michigan
S.E. Mi.
Posted: 01/30/23 04:35am Link  |  Quote  |  Print  |  Notify Moderator
One thing I discovered is my suction line for the generator goes all of the way down to the bottom of the tank. So not all fuel tanks are created equal. The reason I pulled the tank was to replace fuel lines that were 25 years old ( Preventative Maintenance ) It was a good thing because the main fuel line had a goofy hose that was set up like a miniature hydraulic line. I had to take the hose to a hydraulic place with a new fuel hose and he took the fittings off of the old hose and put them on the new one. Try and get this done while broke down on the road.
* This post was edited 01/30/23 04:45am by Brian in Michigan *
4x4van
California
Posted: 02/03/23 10:49am Link  |  Quote  |  Print  |  Notify Moderator
I think that the OP means that since it is currently lower than 1/4, it's a good time to drop the tank (lighter and easier to handle).
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
