RV.Net Open Roads Forum: General RVing Issues: New here! 1986 Holiday Rambler Alternator
 > New here! 1986 Holiday Rambler Alternator
EvelynHoliday
Ventura
Posted: 01/29/23 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hi there!!
I have recently purchased a 1986 Holiday Rambler Chevy 454 p30 Chassis. It started when I bought it and now it won't start at all. My mechanic says it needs a new alternator since the batteries I replaced are brand new.
Any ideas on which alternator to get? I could really use some help--no idea how the whole system works. A manual would be helpful, but it didn't come with one.
Anyone dealing with or dealt with the same issue?
Thanks for your help! I am excited to work on it and get on the road!
MFL
Midwest
Posted: 01/30/23 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum!
If your new batteries are in fact discharged, you need to recharge them right away, as it will ruin them to sit totally discharged.
If you trust your mechanics recommendation, then someone should remove the alternator, take it to a quality auto parts store, to purchase replacement. They can look up replacement needed, and can see if theirs matches the one you have. Often times, you can trade your old one, getting a little savings on the new one.
Good luck, hope you enjoy your recent purchase. Holiday Ramblers were a good model, and the 454 a solid engine.
Jerry
stickdog
Somewhere, USA
Posted: 01/30/23 05:54am Link  |  Quote  |  Print  |  Notify Moderator
You'll need a high output alternator. You have both chassis and house batteries to charge.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
JRscooby
Indepmo
Posted: 01/30/23 06:01am Link  |  Quote  |  Print  |  Notify Moderator
I can agree you want a replacement equal or higher output than original.
When it comes to alternators I have had much better luck marking mine, and taking it in for rebuild instead of part store factory rebuild.
agesilaus
North Florida
Posted: 01/30/23 07:22am Link  |  Quote  |  Print  |  Notify Moderator
NAPA auto parts has parts for old autos and such many times. I would try them first. Rock Auto online is the last resort for old vehicles. That engine however is some major auto engine from that time period. It wasn't made by Holiday.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
EvelynHoliday
Ventura
Posted: 01/30/23 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Ok, thank you. I am calling Napa when they open. I like the idea of taking it out and taking it to Napa so they get the correct match. I am planning to add another Chassis battery, what is a good output for the alternator? We will be living in it and using a lot of power.
enblethen
Moses Lake, WA
Posted: 01/30/23 07:45am Link  |  Quote  |  Print  |  Notify Moderator
You should be able to get replacement locally without too much trouble. I would be looking for one with at least 90-amp output.
If you haven't done so, get a new set of belts at the same time.
NAPA is very pricey!
I would take to a location that performs alternator bench testing. O'Reilly's and AutoZone offer this service.
Around here they can get replacement within a day or so. Both offer lifetime guarantees on some.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
LouLawrence
Traveling the US!
Posted: 01/30/23 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
If you will be living in the RV, the necessary power will not be coming from your engine alternator. The alternator may help keep the batteries charged while driving but once you stop, NADA! You will need a good battery charger, either a converter or an inverter charger larger enough to keep your house batteries charged. It may also be setup to keep your engine starting batteries charged as well (or not).
MFL
Midwest
Posted: 01/30/23 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
^^Above is a good point, especially if adding another house battery. All converter/chargers are not equal, and an 86 model may not have a quality converter, with smart charger. An upgrade to a newer model may be a wise decision, and not a huge expense.
You could post the brand/model you have now, to get more thoughts.
Jerry
ScottG
Bothell Wa.
Posted: 01/30/23 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
More likely than not, you have a Magnatek 63XX converter. In the unlikely event it still works, the battery charge line output is only 3 amps.
You can keep the fuse box and converter body but you'll wan't to plan on upgrading the charger section. You can easily swap it out with a Progressive Dynamics (PDI) unit like a PDI9245 or PDI9260 and get the latest technology.
Check out Best Converter. They have detailed instructions on replacing your charge center.
