RV.Net Open Roads Forum: Replacing AC; can a 15k btu go where a 13.5k btu used to be?
 > Replacing AC; can a 15k btu go where a 13.5k btu used to be?
Cheryl_B
Posted: 01/31/23 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
I got a great deal on a used roof AC but after the guy delivered it to me, the sheer size of its footprint has me concerned. Is this not going to work or will it be okay?
1985 Class C Chevy Rockwood, 27'
Fulltiming since June, 2016. Flying solo but I'm never alone.
Fear not the unknown, but the fear itself.
Cheryl_B
Posted: 01/31/23 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
PS: The rig in my profile is not what I'm currently in. I have to update everything. I'm in a travel trailer now.
ktmrfs
Portland, Oregon
Posted: 01/31/23 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
every one I've seen uses the same 14"? square opening on the roof. that's what's important. Even my 9K BTU polar cub uses the same roof opening size.
And they all seem to be designed for a 20A circuit just like the 13.5K BTU
2011 Keystone Outback 295RE
ItsyRV
Lost on the Blue Ridge Parkway
Posted: 01/31/23 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
The rooftop unit may differ in sizes based on manufacture or profile. As ktmrfs said, the roof opening is universal at 14" X 14".
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
valhalla360
No paticular place.
The mounts/cutout are standard, so no problem.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Cheryl_B
Posted: 01/31/23 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thank God! I was thinking I made a big boo-boo. Thanks so much. Whew!
Posted: 02/01/23 04:58am Link  |  Quote  |  Print  |  Notify Moderator
Short answer YES.
They both fit on a 14" square hole in the roof
The larger one may have a larger box over the hole
But the hole is the exact same size.
deltabravo
Spokane, WA
Posted: 02/01/23 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Yes.
And when you install it, use blue thread lock on the mounting bolts.
Multiple times mine have loosened up and then water leak in under the gasket when it rained.
Other owners have had the same problem.
Video: Threadlock on the A/C bolts.
