RV.Net Open Roads Forum: No 110 Volts to Hot Water Heater Element
 > No 110 Volts to Hot Water Heater Element
#1Flyboy
California
Posted: 02/01/23 10:00am Link  |  Quote  |  Print  |  Notify Moderator
….. Good morning all… Suburban SW6DEL not getting 110 Volts to the heater element. Rocker switch on control panel is sending out 12 Volts when turned on. Is there a relay switch somewhere between the rocker switch and the element? Suggestions appreciated…..TIA
fj12ryder
Platte City, MO
Posted: 02/01/23 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Have you physically checked that you're not getting 120V at the heater element, or assuming so because the element doesn't heat up?
Howard and Peggy
"Don't Panic"
#1Flyboy
California
Posted: 02/01/23 10:08am Link  |  Quote  |  Print  |  Notify Moderator
… tested with volt meter….Circuit breaker is ok… worked for a while yesterday…
enblethen
Moses Lake, WA
Posted: 02/01/23 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Some have two switches. one outside and one inside.
Make and model of water heater would help!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BB_TX
McKinney, Texas
Posted: 02/01/23 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Past reported problems:
- tripped breaker
- bad or tripped thermostat/hi temp cutout
- little black switch on bottom left corner of WH off or bad
- bad relay (located in junction box on WH)
- loose/bad/burned wire connection in any of those areas.
Retired JSO
North Georgia Mountains
Posted: 02/01/23 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Look for an additional 120 volt switch on the water heater itself, suburban located on lower left looking in with outside panel removed. It’s hard to see because of its location behind gas valve.
#1Flyboy
California
Posted: 02/01/23 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Make & model are in my original post; outside lower left 2nd switch is on. Maybe 2nd switch is bad???
Posted: 02/01/23 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Intermittent suggests a short somewhere. Probably harder to find. But easier if it’s not working.
BB_TX
McKinney, Texas
Posted: 02/01/23 11:37am Link  |  Quote  |  Print  |  Notify Moderator
2nd switch is the inside 12 vdc switch that operates the relay at the water heater.
Voltmeter and understanding of the circuit (schematic available in the WH manual) will greatly help in quickly finding the problem.
If you are placing your meter leads across the two terminals on the heating element and not showing 120 vac, it could also actually be loss of neutral. Burned neutral wire in the J box has also been reported multiple times. Try putting one meter lead on the hot side of the element and the other meter lead on the metal frame of the water heater.
enblethen
Moses Lake, WA
Posted: 02/01/23 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Manual. Manual
Yes, there is relay
