RV.Net Open Roads Forum: General RVing Issues: Washer issue driving me nuts
 > Washer issue driving me nuts
Mommalu
Mpls. MN
Posted: 02/03/23 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Stupid me I bought a bucco bucks Bosch dishwasher for the house, 4 yrs later a repairman asks how often do you run this? I said we have a son, his bride and newborn living with us as they find a house, and I do daycare for the grand kids, so 2 maybe 3 times a day. He stated MODERN DISHWASHERS ARE ONLY DESIGNED TO RUN 3 TO 4 TIMES A WEEK!!! I wore it out!! Energy efficient means less water, smaller motors, smaller heating elements, ETC. Pretty sure it's the same for all modern appliances.
With our HE washer I often have to wash clothes twice to remove dirt/odors, or use a heavy perfumed detergent and softner(not going to happen). I also have to wipe the water out of the rubber door gasket to avoid moldy stagnant water sitting in it, and removing the detergent tray and spraying with a bleach & water solution to prevent mold in that dark moist area.
But hey we we're saving the planet even though we are having to run the appliance twice as often to get the results of the old ones running once. Truly I don't understand it, but what are the options?
Wipe out every area, spray with a bleach/water solution and hopefully you can get ahead of the smell & mold.
Sorry for the rant, but its my challenge too.
blaczero
Posted: 02/04/23 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses, had a lot going on yesterday
Is the dryer vented to outside? if so, has it been cleaned?
Have you checked the washer drain vent?
First unit was unvented, new one is vented. I don't really run the dryer ever. The vent/drain below: I opened and drained, also the rubber hose there, opened that and drained. Strangely, the water never smells.
Can you do a smellcheck to see if the clothes smell bad after the wash cycle or the dryer cycle?
first unit, only ran dryer when i first got it, haven't in like a year
just tried with new unit, after dry, they still smell slightly
Do you have a lot of iron in your water? The bacteria and sulfur oxide can make it smell bad. perhaps add a particle and carbon block filter to your supply line and might fix the issue.
not that I know of, i'm on city water down here in the FL keys. I could try a carbon filter
Different location???? Different water supply.
same location/water supply
Yep and all my HE appliances are awful. They're high efficiency either because they use less water, spin less and slower or in the case of my dishwasher don't dry properly because the element is weaker and doesn't stay on long. All these things lead to smells. Water remaining in any appliance will lead to mildew or lingering sulfur smells. Modern appliances simply do not work as well as older models for the sake of efficiency.
I am actually thinking this is what's happening. Since I got the unit brand new and it didn't smell for about 2 weeks (running every day). I figure the water is in the basin left behind from previous cycle and smelling.
i leave the washer door open 100% of the time it's not running. When I had a dishwasher I left the door open as well. I do agree though, the "HE" garbage just means "Hardly Effective" IMO
magicbus
Nantucket Island, MA
Posted: 02/04/23 09:10am Link  |  Quote  |  Print  |  Notify Moderator
The reason you need to leave the washer door open/ mop water from door sill/ spray bleach is because you need to press in and peel back the wide door gasket dead center at the bottom of the door sill and clean the drain holes in it. Ours clogs with dog hair and we clean it regularly. The gasket is attached on one side just for this purpose.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
LMHS
NM
Posted: 02/04/23 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Using an HE (High Efficiency) washer is different than the previous generation of washers. You can't just shove dirty clothes in a big wad. You have to use a light hand and run a smaller load of clothes. I used to get stuck in the appliance dept at Home Depot. I learned a lot about HE washers because so many people had problems with them. Turned out they just needed to adjust how they loaded the machine. Kinda like going from a 700W microwave to a 1000W microwave. There will be some adjustments that need to be learned. HE washers just work better with liquid detergents. So do HE dishwashers and the small countertop dishwashers.
I have a Whirlpool Cabrio TOP LOAD HE washer. I find that I need to put clothes in the bottom of of the tub in a single clump, one item at a time. I start out spacing the clumped items, 6 items in the first layer, evenly around the tub. Then I put a second layer, lightly laid on top of the first layer but off set between the first layer clumps. With shirts, I can run a 3rd layer. I add a Color Catcher sheet and about a cup of baking powder on top of the dry clothes. I buy baking soda in 15 pound bags from Sam's Club.
I use 2 TBSP of a low sudsing coconut oil based liquid dish detergent. The brand I use is the PINK dish detergent from Sam's Club. I use white vinegar in the fabric softener dispenser. I don't use fabric softener in the washer or dryer. I have allergies to many of the fragrances used in laundry detergents.
I run most loads on Normal wash/Heavy soil/High spin/cold wash-cold rinse/Deep clean cycle. My daughter works at Harbor Freight and her work clothes are full of dirty mineral oil. They do come out clean. I don't pretreat her clothes either.
Bedding, coats and towels (I have bath sheets which are heavy oversized towels) are washed on Bulky Wash with all the other settings the same. Bulky Wash uses a higher level of water. But it's still not like the non-HE washers.
I used the same settings and methods when I was using my other daughter's front load HE washer. I also wiped out the door gasket with every use since we had dog hair in the laundry loads.
stickdog
Somewhere, USA
Posted: 02/04/23 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Splendide 2100XL going on 6 years fulltiming. Only time it was not used was one summer in Alaska. Wife does the cleaning routine monthly and only adds vinegar. She leaves the door open a inch or so when not in use. I clean the lint vent every couple months. Hopefully it will last another 6 years.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
SoonDockin
Oklahoma
Posted: 02/05/23 06:17am Link  |  Quote  |  Print  |  Notify Moderator
If the unit does not completely dry out after use and you close it up, it can start to get a moldy smell. We went through that on a front load washer. Now we leave it open for a day and no more moldy smells.
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
way2roll
Wilmington NC
Posted: 02/05/23 07:33am Link  |  Quote  |  Print  |  Notify Moderator
LMHS - tried all that. They still suck.
2023 FR Sunseeker 2400B MBS
blaczero
Posted: 02/05/23 10:18am Link  |  Quote  |  Print  |  Notify Moderator
All indicators point to the "leftover" water from previous load smelling. I use oxy powder in the main tray, and a little blue dawn in the pre-wash tray.
The reason I am thinking its the leftover water is because if I run the load 2x in a row, it smells significantly less.
Very frustrating.
enblethen
Moses Lake, WA
Posted: 02/05/23 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Try running washer cleaning powder.
Tide washer cleaner
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
blaczero
Posted: 02/09/23 05:32am Link  |  Quote  |  Print  |  Notify Moderator
I've tried vinegar, oxy powder, bleach, dawn soap, baking soda.
Would this do better you think?
