RV.Net Open Roads Forum: General RVing Issues: Washer issue driving me nuts
 > Washer issue driving me nuts
blaczero
Posted: 02/02/23 10:20am Link  |  Quote  |  Print  |  Notify Moderator
A while back my washer/dryer combo started to make the clothes smell like mold. After a cycle, they just smelled. Never used to do this, used it for 2 years.
Tried vinegar, bleach, oxy, O3 water, and every solution I could find on the interwebs. Finally gave up, bought a new one.
Now 2 weeks later with the new one smelling fine, the clothes are smelling bad again, same smell as last unit. The first unit was a Magic Chef, this is a Splendide.
Any ideas as far as what to check? We drink the same water that goes into the washer, so I don't know how it could be that.
enblethen
Moses Lake, WA
Posted: 02/02/23 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Is the dryer vented to outside? if so, has it been cleaned?
Have you checked the washer drain vent?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dedmiston
Coast to Coast
Administrator
Posted: 02/02/23 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Can you do a smellcheck to see if the clothes smell bad after the wash cycle or the dryer cycle?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
way2roll
Wilmington NC
Posted: 02/02/23 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a lot of iron in your water? The bacteria and sulfur oxide can make it smell bad. perhaps add a particle and carbon block filter to your supply line and might fix the issue.
2023 FR Sunseeker 2400B MBS
TenOC
On the road -- Full time
Posted: 02/02/23 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Different location???? Different water supply.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
LMHS
NM
Posted: 02/02/23 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
HE washers, top load and front load, are supposed to have a "cleaning" cycle run once a month (I think Splendide manufacturer says every 30 washes). It should have come with the directions for your washer. My HE top loader has a "clean" cycle (just add bleach) just for cleaning. I find it easier to run the clean cycle on the 1st day of every month. Otherwise you can buy a product called Affresh and run that in a cleaning cycle OR a short cycle (NOT a fill and dump cycle but an actual wash cycle). On a front loader, you MUST wipe out the backside channel of the flange around the door as it will smell nasty and can also make your clothes smell. You may not notice your clothes smelling if you use a heavily scented fabric softener or detergent (do you smell like "Eau de Gain" or a similar detergent/softener?). Don't forget to clean the detergent/bleach/softener dispenser cups.
larry cad
ohio
Posted: 02/03/23 04:23am Link  |  Quote  |  Print  |  Notify Moderator
OK, I give up! What is a "HE" washer???
Never mind, I figured it out!
Our Travel Blog
Campinghoss@51
Windsor NC
Posted: 02/03/23 04:27am Link  |  Quote  |  Print  |  Notify Moderator
When we had our motorhome we noticed that some of the cg's potable water was very hard. Our washer/dryer combo would have an off order sometimes. I purchased a on the go water softener and never smelled the off odor again. Sold the motorhome and went back to the fiver in my sig. The washer smells fine all the time now. None of our faucets have any signs of stain either. I highly recommend a softner if you don't know your water supply.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
Campinghoss@51
Windsor NC
Posted: 02/03/23 04:29am Link  |  Quote  |  Print  |  Notify Moderator
HE - stands for high efficiency
way2roll
Wilmington NC
Posted: 02/03/23 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Yep and all my HE appliances are awful. They're high efficiency either because they use less water, spin less and slower or in the case of my dishwasher don't dry properly because the element is weaker and doesn't stay on long. All these things lead to smells. Water remaining in any appliance will lead to mildew or lingering sulfur smells. Modern appliances simply do not work as well as older models for the sake of efficiency.
* This post was edited 02/03/23 07:46am by way2roll *
