RV.Net Open Roads Forum: Fifth-Wheels: Wearing under bedroom slide ???
 > Wearing under bedroom slide ???
ilvtravln
Calif.
Posted: 02/06/23 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
The rollers are wearing on the underside of the bedroom slide, I priced stainless 10" by 27" 1/8 thick was told $750. for 2 pieces, seems a bit high, is there an alternate material I can use that's more reasonably priced. Thanks
Art
Allworth
Orlando, FL
Posted: 02/06/23 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Most Titanium owners have reinforced with construction grade aluminum. 3/32" is plenty thick.
Do you have a plan for installing??
A
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
ilvtravln
Calif.
Posted: 02/06/23 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
A
Yes, will install myself, thanks
* This post was edited 02/09/23 11:17am by ilvtravln *
FLY 4 FUN
Alberta
Posted: 02/06/23 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
do it before it wears out the Darco material or you will be facing a costly repair if moisture gets into the MDF lining the slide. I tried tape and various coatings but ultimately had to get the slide rebuilt as water wicked down the sides of slide and then along the now porous and torn liner.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
ScottG
Bothell Wa.
Posted: 02/06/23 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Check onlinemetals.com.
* This post was last edited 02/08/23 09:05pm by ScottG *   View edit history
ilvtravln
Calif.
Posted: 02/09/23 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Material underside of slide is in good shape, no cracks or holes, want to install stainless steel ahead of any problems. Thanks
Bipeflier
Centralia, MO
Posted: 03/29/23 09:16am Link  |  Quote  |  Print  |  Notify Moderator
I'm a little late to the party but check out McMaster-Carr.com
McMaster-Carr Stainless 12 X 36
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
shadows4
Kansas City, Mo
Posted: 03/29/23 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
1/8 inch thick seems a bit extreme to me. Thin aluminum would be cheaper and easier to use I would think. I haven't done it yet but have been thinking about it as I have had to rebuild our bedroom slide.
I also used a short piece of aluminum drip rail to help stop the wicking. Seems to work well. Good luck.
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 223,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
Allworth
Orlando, FL
Posted: 03/30/23 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Try aluminum plate. Watch out for the thickness of the plates causing the top of the slide to jam in the opening just as it closes completely.
I tried 3/16" and had to remove them and go to 3/32". Plenty stiff.
Google 'specialty aluminum plate'.
Cummins12V98
on the road
Posted: 04/01/23 08:42am Link  |  Quote  |  Print  |  Notify Moderator
14ga is what fellow DRV owner placed on his slide bottom with no deflection.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
