RV.Net Open Roads Forum: Fifth-Wheels: Calc. Turn Radius w/Truck + 35' 5er
 > Calc. Turn Radius w/Truck + 35' 5er
ArcadiaArch
California
Posted: 02/06/23 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hello. I am designing a new driveway to accommodate a GMC Sierra 2500 Crew Cab and a not-yet purchased 35' 5th wheel. What is the best way to approximately calculate the necessary turning radius for this combo?
I've scoured the internet and spoken to several RV dealers and no one can offer any help. Anyone hear have any advice? Thank you!
ford truck guy
Pennsylvania
Posted: 02/06/23 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
In MY opinion.... way too many contributing factors to answer properly....
Good luck with your search..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Mfan
Otsego,Mi
Posted: 02/06/23 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Short bed, long bed? Sliding hitch or fixed? Just for starters
MFL
Midwest
Posted: 02/06/23 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
^^Agree, even if someone here gave a formula to calculate, would you trust it to construct your drive accordingly?
A given is, a FW will always turn inside of truck track. The longer the arc, the shorter it cuts.
Jerry
fj12ryder
Platte City, MO
Posted: 02/06/23 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
And how sharp are you willing to turn? 90°? More? Less? Shoot, turn sharp enough and the trailer will basically pivot on its wheels. But not good for the trailer frame and running gear.
Howard and Peggy
"Don't Panic"
CarnationSailor
Cathedral City, CA
Posted: 02/06/23 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 36-foot 5th-wheel that I tow with a 2015 Silverado 2500 Crew Cab. Prior to moving, I lived on a cul-de-sac with a 55-foot diameter. I could turn in the cul-de-sac and never approached 90-degrees between the truck and trailer. I would guess the closest I came to it was 120-degrees.
Hope this helps.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
CarnationSailor
Cathedral City, CA
Posted: 02/06/23 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Try this:
https://truckscience.com/en-us/turning-circle-calculator/
stickdog
Somewhere, USA
Posted: 02/06/23 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Must be a vacant parking lot nearby.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
BB_TX
McKinney, Texas
Posted: 02/06/23 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Google.
One set of examples.
That would be the tightest outside radius of the truck. Since the 5er turns inside the truck the inside radius would vary quite a bit on trailer length, hitch type, etc. Probably have to go to a large open parking lot and do some measuring between outside radius of truck tires and inside radius of trailer tires.
Then you would need to add a safety margin on both sides.
MFL
Midwest
Posted: 02/06/23 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Some good ideas being mentioned, but keep in mind, OP has not purchased FW yet, but wanting to design driveway with a 35' in mind.
