RV.Net Open Roads Forum: Fifth-Wheels: Calc. Turn Radius w/Truck + 35' 5er
 > Calc. Turn Radius w/Truck + 35' 5er
valhalla360
No paticular place.
Posted: 02/06/23 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
In the road design business, look up "turning templates". Mostly built into CAD software but the old guys will have scale sheets they can lay on plans.
Of course, there is a cheat, go on google earth and look at campgrounds till you find something similar to the layout you want. Then take measurements off that. So long as the campground handles 35ft 5ers regularly, should work fine for you.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
schlep1967
Harrisburg, PA
Posted: 02/07/23 10:31am Link  |  Quote  |  Print  |  Notify Moderator
That's a tough number to come up with. Remember you are not working with the full 35 feet in length. Your length to worry about is the pin to the rear axle. With a 35 foot fifth wheel you may only be looking at 25-27 feet or less.
A big part of your design needs to be based on the width of the roadway you are backing in off of. If you have 24 feet of road width and no real close obstructions to the sides, you should be able to get the trailer into a very narrow driveway. Provided you start from the far side of the road.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
msmith1.wa
Tacoma, WA
Posted: 02/07/23 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
This is what the road designers where I work use. Looks like an account is needed even for a trial. If you know someone that does road or even parking lot design ask them if they can run throughwhat ever software they have.
https://www.transoftsolutions.com/vehicle-swept-path/autoturn-online/
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
schlep1967
Harrisburg, PA
Posted: 02/08/23 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Those turning templates are for going forward. Totally different than backing in. Now if you can find what they use to design a loading dock in the city, that would be the right stuff.
schlep1967
Harrisburg, PA
Posted: 02/08/23 05:26am Link  |  Quote  |  Print  |  Notify Moderator
ArcadiaArch wrote:
Hello. I am designing a new driveway to accommodate a GMC Sierra 2500 Crew Cab and a not-yet purchased 35' 5th wheel. What is the best way to approximately calculate the necessary turning radius for this combo?
I've scoured the internet and spoken to several RV dealers and no one can offer any help. Anyone hear have any advice? Thank you!
I guess someone should have asked this by now. Are you looking at a pull through driveway or a back in driveway? As that would be two totally different designs.
JRscooby
Indepmo
Posted: 02/08/23 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Good question. I have been assuming he wanted to know how small he could build something like a traffic circle. Someplace to drive around a circle without backing up.
bucky
Raleigh metro
Posted: 02/09/23 04:09am Link  |  Quote  |  Print  |  Notify Moderator
Although it isn't as easy as it sounds if you can pull in you should be able to back out. I'm not real good at the concept though. [emoticon]
Puma 30RKSS
JRscooby
Indepmo
Posted: 02/09/23 04:25am Link  |  Quote  |  Print  |  Notify Moderator
But if there is a chance of traffic it is much safer to back out of traffic than back into it.
TXiceman
Bryan, TX
Posted: 02/09/23 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Remember that all of the sites having a calculation method for large trailer rigs are based on commercial tractors and commercial 5th wheel trailers. These 5ers have the trailer axles at the very rear of the trailer and will behave differently than a typical RV 5er with the axles closer to 60% of the trailer length.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Allworth
Orlando, FL
Posted: 02/10/23 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
OP?
OP?
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
