RV.Net Open Roads Forum: Tow Vehicles: Ram 1500 owners.... tires
Search only in Tow Vehicles
 > Ram 1500 owners.... tires
huskyfan68
usa
Posted: 02/07/23 08:15am Link  |  Quote  |  Print  |  Notify Moderator
tried posting this on Ram site but no answers- I tow with a 2014 Ram 1500 Hemi- quad cab- Has stock 275/60 R20 tires on and needs new ones.
Anyone know largest size I can put on without any sort of lift?
* This post was edited 02/07/23 09:00am by huskyfan68 *
MFL
Midwest
Posted: 02/07/23 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Since you have the truck, with current tires/wheels installed, you'd be best able to answer your own question.
Knowing diameter of what you have, and being able to see what clearance is available, measure how much space, and still allow some amount of clearance before rubbing. Look up the diameter of whatever tire you may be considering.
It is possible someone here, may have same truck, BTDT, and could tell what worked for them?
Jerry
Posted: 02/07/23 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
What he said!
And then get some LT E load tires if you’re towing anything significant or just want to experience much longer tire life for not much more money.
ssthrd
Vancouver Island
Posted: 02/07/23 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe give Discount Tire or Tire Rack a buzz.................
Caution though because I have the largest tire recommended by DT on my bone stock truck, and they just touch the inner fender liner at full lock.
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
TurnThePage
North ID
Posted: 02/07/23 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I ran 305/55r20s on a 1.4" lift on my 2015 Ram Quad Cab. It's not really a lift at all when it comes to clearance issues. In fact a coworker had a similar Ram that sat at virtually the same height with no lift at all. My wheels had 3/4" less back spacing though, which means they stuck out that much more. That really should only affect clearance of the upper ball joint which is pretty close. I bet the dealer would test fit a tire to see how close everything is.
Unless you're talking about a taller tire. I think people routinely run 275/65r20 on stock rims with no lift. That's about an inch taller. Dunno if you can go more than that or not. Once again a test fit might tell you all you need to know.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
shelbyfv
TN
Posted: 02/09/23 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
What he said!
Agree. IME they noticeably increased stability at the rear of the truck with no downside.
Posted: 02/09/23 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Another @wuts duh biggest tirez i’s kin fit? …..thread
blt2ski
Kirkland, Wa
Posted: 02/10/23 11:19am Link  |  Quote  |  Print  |  Notify Moderator
I have LR E tires on my GM 1500, I've never had enought load in the bed to need 80 lbs on the rear tires! needed 45-50. Or what an XL/ LR C tire is PSI rated too. Unless like mine you are running 8000 lbs per axle. WHY have LR E tires?
WIth this said, I have no idea what size you can do stock on a Dodge. I's swag I had clearance for the 28-65-18 32.5" tires I upgraded to vs 265-65's at 31.5". I did do a 2" strut leveling kit in the front, and a helper spring that lifted the rear around 1.5". My sone thinks his 305-65-18's will fit. He has a 4" lift on his 05 GM reg cab.
I've done 1" diam changes on my SW 3500's in the past with out issues.
Marty
2014 Chevy 1500 Dual cab 4x4
mkirsch
Rochester, NY
Posted: 02/10/23 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty sure that was the whole point of asking.
Posted: 02/10/23 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
@Marty, what is the point of LRE tires on a half ton (assuming no need for the additional weight capacity like you mentioned)?
Because what I said above. Greater value typically. I’ve run through a lot of tires and heavier duty tires last longer proportionally than the increase in purchase price.
Also means you’re driving on the “top half” of the tread longer. You know the good part where you get better traction.
And generally increased puncture and damage resistance. Or less value on a total pavement princess truck, but a lot of folks do truck stuff with their trucks.
