RV.Net Open Roads Forum: Tech Issues: Propane smell inside oven
 > Propane smell inside oven
ernie1
Sacramento,California,USA
Posted: 02/08/23 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Is your propane level low? If so, then the mercaptans in the propane will start to smell because it is more concentrated in the bottom of the tank. That's why both the pilot light and the burner produces an odor. Just refilling the propane tank will take care of the problem.
enblethen
Moses Lake, WA
Posted: 02/08/23 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I turn off the pilot to the oven to save fuel and make my feeble safety mind a little happier. This while we are traveling not when setup.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
joebedford
Home for the summer.
Posted: 02/08/23 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Why are you leaving oven pilot on when not backing or broiling?
I don't know what backing is but we leave it on because to light it, one of us has to get down on the floor and reach backwards with a lighter while holding the pilot knob pressed in.
enblethen
Moses Lake, WA
Posted: 02/08/23 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
That should be BAKING!
auto correct sucks!
Bobbo
Wherever I park
Posted: 02/08/23 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
When we leave our oven pilot light lit for a few days, my wife can smell it. What she smells is not propane though, it is propane combustion byproducts. Get a propane detector and put it in there. They are very sensitive. If there is propane, it will tell you. Otherwise, it is probably combustion byproducts you smell.
Bobbo and Lin
Roger10378
Goodrich, MI.
Posted: 02/09/23 05:20am Link  |  Quote  |  Print  |  Notify Moderator
My thought as well.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Vintage465
Prunedale CA.
Posted: 02/09/23 07:59am Link  |  Quote  |  Print  |  Notify Moderator
I had the same thing going on and it was a real small fuzz leak where the tube tightened into the pilot assembly. Tightened, smell gone.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
S Davis
Western WA
Posted: 02/09/23 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Get some soap bubbles and check your pilot tube, the nut at the pilot and at the gas valve. I have found lots of small leaks on pilot tubes over the years.
2oldman
NM
Posted: 02/10/23 07:59am Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
We turn the pilot light on when we use the stove. It has a piezo-electric igniter so not a big deal.
A piezo lights the pilot that then lights the stove?
