RV.Net Open Roads Forum: Technology Corner: Laser printer/scanner recommendation?
 > Laser printer/scanner recommendation?
Matt_Colie
Southeast Michigan
Posted: 02/11/23 08:40am Link  |  Quote  |  Print  |  Notify Moderator
For about six years, what is now our RV was my office (and more). I have had a color laser in the home office all that time and loved it, but it is power hungry and huge. Admittedly, I always saved the big printing jobs for when I got home, but having the multi-function onboard was a terrific help.
Toner for the laser lasts a long time, but is also seriously expensive.
Ink for the little ink jet is also expensive, but this one has the print head as part of the cartridge. This is good and bad. That makes them expensive, but it also means that if a print head clogs, you can try cleaning it really fast (about a 50% success rate), or change it out to get on with the required printing.
Space and storeage in the coach are at a premium. The ink jet could stow its cables (it was not wireless), and it could run off the tiny inverter forever (we didn't have the big inverter then). It lived under the towels in the linnen cabinet when not in use. This was all in Michigan and I never had a cartridge dry out before it ran out.
You are going to have to do your own market research, because both of my printers are out of production.
Before you get too far along, look at your schedule C and remember that you can deduct the cost of the printer and supplies right up front.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
Hemi Joel
Minnesota
Posted: 02/11/23 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Well, I spent way too much time searching for something that met all of my criteria. I don't think it exists. So I pulled the trigger on a Cannon imageCLASS MF3010 VP. It doesn't have wireless, or a document feeder, and it prints in black only but scans in color. But it is very compact at 10.9 x 14.7 x 10 inches, and only weighs 14 pounds. And it was only $120. It will be easy to stow away, and dig it out and put it on the table only when needed.
Thanks for all the suggestions, and the time you all took to answer! Joel
2018 Eagle Cap 1163 triple slide, 400W solar, MPPT, on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
fj12ryder
Platte City, MO
Posted: 02/11/23 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
It scans in color but has no way to print in color, which I thought you wanted. You can't print a scanned page in color.
Howard and Peggy
"Don't Panic"
1492
Arlington, VA
Posted: 02/11/23 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
I've had very good luck with Brother laser printers and have experienced no failures. When the toner indicates out, I just reset the cartridge and keep printing. Have discovered that there must be a significant amount of toner still intact, as I can keep printing quite a number of pages before the quality degrades.
I've only used aftermarket toner and have had no problems. In fact, our IT printer tech at my office only buys aftermarket HP compatible color toner cartridges. Have experienced no degradation in print quality. Saves a significant expense over HP toner. BTW, my office is no small operation, part of the largest organization of its kind in the world.
This is a Signature test on RV.net forum portal.
