RV.Net Open Roads Forum: Fifth-Wheels: Vanleigh Power issue bedroom nose sockets
 > Vanleigh Power issue bedroom nose sockets
tourusa
Ft Lauderdale
Posted: 02/10/23 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Socket and power issues
I have lost power to certain power sockets in the bedroom, washer dryer, next to the bed and on the bedside cabinet.
The others in the bedroom the ceiling tv and other side of the bed works fine
Any ideas I’ve checked each socket and all look intact
I’ve checked the gfi in the bathroom which is the closet and that works, any ideas
No breakers are off and even replace one just in case
Picture below
RED no power
Blue working
* This post was last edited 03/09/23 04:32pm by tourusa *   View edit history
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
tourusa
Ft Lauderdale
Posted: 02/10/23 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
tourusa
Ft Lauderdale
Red in the picture aren’t working
Blue are working power sockets
enblethen
Moses Lake, WA
Posted: 02/10/23 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Does your rig have an inverter that feeds some of the receptacles? Could be tripped breaker on it.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
midnightsadie
ohio
Posted: 02/11/23 05:01am Link  |  Quote  |  Print  |  Notify Moderator
loose wire in a junction box?
tourusa
Ft Lauderdale
Posted: 02/11/23 06:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all the inverter only feeds the fridge
Junction box do they look the same as at home silver with a blank face plate
tourusa
Ft Lauderdale
Posted: 02/11/23 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I’m thinking the washing machine being in the nose worked the cable free whilst running
alboy
Kelowna B.C.
Posted: 02/11/23 08:08am Link  |  Quote  |  Print  |  Notify Moderator
check outside gfis as well as all others.
tourusa
Ft Lauderdale
Posted: 02/11/23 08:20am Link  |  Quote  |  Print  |  Notify Moderator
You know I’ve only found 2 gfi non outside and I’ve looked everywhere
The three sockets out side are one in the wet bay, one underneath and two near the outside door.
I’m thinking this started when the washing machine was running then it stopped as the power was cut to those sockets in red, bizarre
C Schomer
Pueblo West, Co.
Posted: 02/15/23 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
I'd pull the other receptacles and check the chincy push-blade connectors for anything that might have worked loose.
One of my first RVs had a staple shot into a romex.
