RV.Net Open Roads Forum: Fifth-Wheels: Vanleigh Power issue bedroom nose sockets
 > Vanleigh Power issue bedroom nose sockets
tourusa
Ft Lauderdale
Posted: 02/15/23 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks I got a response from the manufacturer and there is a feed from the wet bay to check which goes up to the other bad sockets
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
tourusa
Ft Lauderdale
Posted: 02/28/23 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks I checked all in the nose and checked the one on the nose vanleigh suggested and still no luck finding the issue
tourusa
Ft Lauderdale
Posted: 03/09/23 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Posting wiring diagram from Tiffin. Any input appreciated
Should help vanleigh owners
enblethen
Moses Lake, WA
Posted: 03/09/23 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a link for the wiring diagram?
Looks like a very generic diagram.
It is difficult to read!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tourusa
Ft Lauderdale
Posted: 03/09/23 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
https://drive.google.com/file/d/1QWGvOxohowRk65czcwiMAZqlrlyXl1Ny/view?usp=drivesdk
Thanks
tourusa
Ft Lauderdale
Posted: 03/09/23 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
My next thought was just to replace the gfi in the bathroom and check the white and black to the bottom of the fuse panel rail are tight. Vanleigh asked me to check the wet area socket which I did and all was seated correctly, my next thought was to take the cover off the junction box below in the belly picture below
tourusa
Ft Lauderdale
Posted: 03/09/23 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen
Moses Lake, WA
Posted: 03/09/23 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Check for power in the bedroom switch and receptacle box. It feeds GFI in bath.
tourusa
Ft Lauderdale
Posted: 03/10/23 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Morn the bath has a gfi should I switch this one out just in case, it has green light. Only 50 percent of sockets are not working currently in the bedroom area, highlighted in red in my initial post
enblethen
Moses Lake, WA
Posted: 03/10/23 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Use a voltmeter and check the load terminals on GFI. Don't throw parts at problem!
