RV.Net Open Roads Forum: General RVing Issues: Should I paint galvanized vent caps?
 > Should I paint galvanized vent caps?
mtnbbud
Oregon Willamette Valley
Posted: 02/12/23 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I'm replacing my plastic pipe vent caps with galvanized metal caps. Should I paint them before or put the on, or with the galvanization be enough?
If I do paint them, does anyone have recommendations for which paint to use and prep work. There's a small bolt and nut on the top of these. I'm thinking cover these with some Dicor?
TenOC
On the road -- Full time
Posted: 02/12/23 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Galvanized steel will last for 10+ years without rusting. Do remember the old metal galvanized steel garbage cans?
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
wildtoad
Blythewood, SC
Posted: 02/12/23 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
The only reason to paint them is if you want to have them match the pipe or other rooftop parts.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
C Schomer
Pueblo West, Co.
Posted: 02/12/23 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
So many paints won't stick. Do what tinners do... wipe galvanized metal with vinegar to etch it. Craig
enblethen
Moses Lake, WA
Posted: 02/12/23 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I would suggest painting with a good quality paint. Make sure to wipe down with vinegar to get good adhesion. The thin metal of your cap is most likely electro-galvanized and not hot dipped. Electro-galvanizing doesn't last!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
JimR 1
Custer South Dakota
Posted: 02/12/23 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
I worked at a hardware store and if I remember there is a primer or paint made for Galvanized metal
JimR
mtnbbud
Posted: 02/12/23 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for your input. I believe the original plastic covers made it 30+ years, but I figure I might as well be sure and paint them if there's a chance they will eventually rust. There's a Sherman Williams paint store near my house. They should know what primer and paint I should use. I might even bring along the caps when I ask them. Better to play it safe than to have to replace them in the future...
enblethen
Moses Lake, WA
Posted: 02/12/23 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
One or two coats Rust-oleum or Hummerite paint. Big issue is to neutralize the galvanizing using cheap white vinegar. Use stainless screws for mounting.
