RV.Net Open Roads Forum: Tech Issues: Harvesting Solar
 > Harvesting Solar
StirCrazy
Kamloops, BC, Canada
Posted: 02/18/23 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Cptnvideo wrote:
StirCrazy, I understand about the bar fridge, but there are other advantages to upgrading solar and batteries. We started out with 1200 watts solar and 618 ah of LFPs. Then added 400 more watts, then I added 2 more LFPs. I'm about maxxed out, not much room on the roof for more solar and adding more would require a controller upgrade.
oh ya definatly, I have three 180 watt 12V panels on the fith with a PWM controler and four 6V batteries so a usable 200ish AH. when I do that upgrade I am going to switch to three 350ish watt 24V panels MPPT controler and then Ill put about 900AH of LFP in there. I figure that battery capacity will give me about a 9-10 day reserve at my current usage, or once I start running the bar fridge that could drop down to a 3-4 day reserve if the solar ***** out. the increase in solar should put me up to around 60 amps or more of charging for the good 4 or 5 hours so thats more than enough to charge and run the bar fridge through the day. I do have the advantage of not needing my AC and a lot of the 120V stuff in normal situations. I carry two coffee pots a perculator and a kieurg, a regual toaster and a camp stove toaster and so on so if we are having issues with power it isn't a hardship to reduce my power usage.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Cptnvideo
Arizona - most of the time
Posted: 02/18/23 10:15am Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy, solar and batteries are kind of like fun, mayo and butter & sour cream - there's no such thing as too much. [emoticon] [emoticon]
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
Cptnvideo
Posted: 03/25/23 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
We're currently camping near Bouse, AZ on BLM land. Our Victron solar controller app showed a solar harvest of 7.57 kwh yesterday. Had to cycle the electric water heater to maximize harvest. Typical TV, lights, res fridge, microwave and LP furnace blower loads.
StirCrazy
Posted: 03/26/23 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I kinda look at it the same way, but my wallet will argue with you [emoticon]
 > Harvesting Solar
