RV.Net Open Roads Forum: Aqua Magic Style 2 - bowl leaks down
 > Aqua Magic Style 2 - bowl leaks down
joebedford
Home for the summer.
Posted: 02/12/23 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced the ball valve and the water valve on the toilet. It was jamming and leaking - it doesn't do either of these any more.
However, maybe 75% of the time, the bowl won't retain water. It's a new gasket that came with the ball valve.
I don't know what I did wrong; I can't imagine what can be adjusted to make it hold water.
Suggestions? (no, I'm not going to get another brand of toilet)
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 02/12/23 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Very common problem with that Model/Brand of toilet, that's the reason many have switched to the Dometic brand.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
midnightsadie
ohio
Posted: 02/12/23 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
look around real close, maybe a lip out of place give it a cleaning ,could be just a piece of grud in the way. OR do it again sam.
ROBERTSUNRUS
Salem, Oregon
Posted: 02/12/23 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, I just spray Silicone on the ball, around the seal. I found that just water and RV antifreeze will dry out the seal and it will drain, and stick. Manufacture says to only use silicone on the seal.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
JimR 1
Custer South Dakota
Posted: 02/12/23 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the shroud is pushed back from the flush pedal
JimR
Itinerant1
Itinerant
Posted: 02/13/23 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Put some plumbers grease on the seal, it will help with the ball movement and sealing or atleast with mine.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,400+ partial cycles.
JKJavelin
Milwaukee, WI
Posted: 02/13/23 09:44am Link  |  Quote  |  Print  |  Notify Moderator
X2
After several years of this problem, I replaced the seal last summer, and 2 weeks later it started leaking again. I smeared some plumber's grease around it and it was good for a long time. Had to do it again about 2 weeks ago. I can feel the difference in the foot pedal. I believe that the ball was not fully closing from too much friction.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 75 Nights
ScottG
Bothell Wa.
Posted: 02/13/23 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Clean the underside of the seal where it contacts the ball. One of my toilets came with a disposable nail file for this purpose.
ernie1
Sacramento,California,USA
Posted: 02/13/23 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Be careful when you purchase "plumber's grease". It could be a petroleum product or it could be silicone. Only use silicone products because petroleum will react with the seal and ruin it.
Itinerant1
Itinerant
Posted: 02/13/23 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Good point.
The particular kind that I've been using Oatey faucet and valve grease which is comprised of silicone oil (polydimethylsiloxane) in combination with silicone grease.
