joebedford
Home for the summer.
I just replaced the ball valve and the water valve on the toilet. It was jamming and leaking - it doesn't do either of these any more.
However, maybe 75% of the time, the bowl won't retain water. It's a new gasket that came with the ball valve.
I don't know what I did wrong; I can't imagine what can be adjusted to make it hold water.
Suggestions? (no, I'm not going to get another brand of toilet)
Michelle.S
Western NY till fall, then Sebring, FL
Very common problem with that Model/Brand of toilet, that's the reason many have switched to the Dometic brand.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
midnightsadie
ohio
look around real close, maybe a lip out of place give it a cleaning ,could be just a piece of grud in the way. OR do it again sam.
ROBERTSUNRUS
Salem, Oregon
Hi, I just spray Silicone on the ball, around the seal. I found that just water and RV antifreeze will dry out the seal and it will drain, and stick. Manufacture says to only use silicone on the seal.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
JimR 1
Custer South Dakota
Make sure the shroud is pushed back from the flush pedal
JimR
Itinerant1
Itinerant
Put some plumbers grease on the seal, it will help with the ball movement and sealing or atleast with mine.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,400+ partial cycles.
JKJavelin
Milwaukee, WI
Itinerant1 wrote: Put some plumbers grease on the seal, it will help with the ball movement and sealing or atleast with mine.
X2
After several years of this problem, I replaced the seal last summer, and 2 weeks later it started leaking again. I smeared some plumber's grease around it and it was good for a long time. Had to do it again about 2 weeks ago. I can feel the difference in the foot pedal. I believe that the ball was not fully closing from too much friction.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 75 Nights
ScottG
Bothell Wa.
Clean the underside of the seal where it contacts the ball. One of my toilets came with a disposable nail file for this purpose.
ernie1
Sacramento,California,USA
Be careful when you purchase "plumber's grease". It could be a petroleum product or it could be silicone. Only use silicone products because petroleum will react with the seal and ruin it.
Itinerant1
Itinerant
ernie1 wrote: Be careful when you purchase "plumber's grease". It could be a petroleum product or it could be silicone. Only use silicone products because petroleum will react with the seal and ruin it.
Good point.
The particular kind that I've been using Oatey faucet and valve grease which is comprised of silicone oil (polydimethylsiloxane) in combination with silicone grease.
