RV.Net Open Roads Forum: Tech Issues: Ok who knows there toilet/black tank systems
 > Ok who knows there toilet/black tank systems
StirCrazy
Kamloops, BC, Canada
Posted: 02/13/23 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Ok so the used camper I bought three years ago has and issue I havent been able to track down yet. so the toilet works perfect, tanks are good (I had to change the guts of the dump valve as it was weeping)
but I still have an issue
so when I am driving and pull over to use the washroom or when we get to the campground and I go to use the washroom right away it smells like a outhouse. this goes away and it is fine for as long as we are camping.
so it only happens when I am driving, the vents are closed when I am driving so its not getting sucked in the roof vents, the seal in the toilet holds water, and there is a little water in the bowl when I am driving.
any ideas where I should look next??
thanks
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
enblethen
Moses Lake, WA
Posted: 02/13/23 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Water sucked out of drain traps
No water in drain traps
Vent under washroom sink stuck open, if equipped. air admittance style vent
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
opnspaces
San Diego Ca
Posted: 02/13/23 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Yes probably an air admittance vent AKA cheater valve the is not longer a one-way valve. Available at Lowes or Home Depot for around $10
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
MFL
Midwest
Posted: 02/13/23 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I agree, it doesn't sound like the black tank could be the issue.
Easy to fill drain traps, including sinks and shower, when stopped. Does smell go away?
Jerry
WNYBob
Tonawanda, NY
Posted: 02/13/23 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I just saw a post this week where someone solved his issue with black tank smells. He changed the floor seal and the toilet.!
opnspaces
San Diego Ca
Posted: 02/13/23 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Before your next trip pour a cup of pine sol down your kitchen sink drain. Then run the tap and wash the pine sol out of the trap and into the gray tank. When you get to your destination you'll know if the smell is coming from the black or gray tank. (credit to Doug Rainer on this idea)
Posted: 02/13/23 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
^Bingo. Or black vs gray smell is typically totally discernible to all but the most oblivious sewer dumper. Lol
Does it happen all the time or only if traveling with partially to very full black tank?
Only had 3 “RVs” now but all of them were the same, both older and fairly new units. If black tank was fairly full and we’d travel a distance, like any sustained highway driving, the black tank odor would come into the camper.
Not the P traps or gray.
And no other odor issues.
Seal around bottom of toilet like mentioned recently could be it.
My solution was to dump what I hoped I could have dumped 100miles sooner, lol.
* This post was edited 02/13/23 01:01pm by Grit dog *
RLS7201
Posted: 02/13/23 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
If the Air Admittance Vent doesn't fix your issue. There is another possible reason for the stink inside your RV. When going down the road, the inside of the RV goes into a negative pressure, caused by the large flat area in the rear. This allows the pressure differential to induce a stink in the RV. I replace the caps on the roof vents with sanitary Ts, to put the tanks into the same pressure as the inside of our MH. Or you can purchase the rotating roof vents. Rotating roof vents.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
StirCrazy
Posted: 02/14/23 07:31am Link  |  Quote  |  Print  |  Notify Moderator
all p traps still have water, that was my first thought..
I'll have to go look again I have never seen an atmittance valve in this camper.
Steve
* This post was edited 02/14/23 07:40am by StirCrazy *
StirCrazy
Posted: 02/14/23 07:32am Link  |  Quote  |  Print  |  Notify Moderator
there all p traps. and why would that be on the black water system?
* This post was edited 02/14/23 07:39am by StirCrazy *
