RV.Net Open Roads Forum: Can the grid keep up with EV use?
Open Roads Forum  >  Around the Campfire
 > Can the grid keep up with EV use?
Page of 16
Reisender
NA
Posted: 02/13/23 06:29pm Link  |  Print  |  Notify Moderator
This will help. And all are 350 kw which will line up nicely with the 800 volt architecture of the electric pickups coming down the line. And from what I understand pull thru sites will be offered. Cool.
TravelCenters of America Enters Agreement with Electrify America to Expand Electric Vehicle Infrastructure.
https://www.businesswire.com/news/home/2........o-Expand-Electric-Vehicle-Infrastructure
Reisender
NA
Posted: 02/13/23 06:35pm Link  |  Print  |  Notify Moderator
KD4UPL wrote:
Forget the grid, the electrical infrastructure in most homes and neighborhoods can't handle total conversion to EVs. Many homes still have 60 amp services. Most homes in the US have 100 amp services. A level 2 charger can draw from 30 to about 60 amps depending on the model and the charge level of the car it's charging. This leaves very little service capacity for the other loads in the house. With gas and oil heat being forced out in favor of heat pumps it makes the situation even worse. Most homes in this country will need a new service to handle EVs alone, not to mention full electrification.
A 25 kVA transformer is a common size to supply 1 or more homes. These are roughly rated for 100 amps. If this is what's feeding your home, even if you have a 200 amp service, adding an EV could easily overload the transformer. In households that would have 2 or more drivers and thus multiple cars charging the power company will likely need to upgrade the transformers. In some older neighborhoods it's not uncommon for one 25 kVA transformer to feed several homes; I've seen up to 6 personally.
My vacation house is fed with a 15 kVA transformer. I was looking at putting in a tankless water heater instead of our tank type. A tank type WH uses 4.5 kVA. The size tankless heater I would need was going to be 20 kVA. Obviously I can't run that on a 15 kVA transformer. The power company wanted $5,000 to upgraded it. I"m sticking with my tank type. I had thought about adding an electric car charger at the cabin to make it more appealing to renters. But, after figuring the water heater, well pump, air conditioning, and other loads there wasn't enough capacity for a charger.
This doesn't even address the power company feeders in neighborhoods. If everybody on a cul-de-sac fed by the same feeder gets their electric cars charging at once the feeder will be overwhelmed.
Most people will be charging their cars at home at night. Solar panels don't work at night. I should know, I install them for a living. That means that most of the energy to charge these cars will be coming from coal, natural gas, and nuclear.
Then there's construction, mining, logging, and farm equipment that isn't parked anywhere near the grid. If that is electrified where are they supposed to charge?
Yah. All valid concerns. But for most people a 16 amp 240 volt connection is more than adequate for the typical driver. We have a 100 amp service on our town house. But one of our neighbours has a hot tub so the electrician just installed a 20 amp 240 volt circuit which he runs at 16 amp. We have similar commutes. He has no problem. Either way we are both charged in the morning.
d1h
Indiana
Posted: 02/13/23 06:59pm Link  |  Print  |  Notify Moderator
Lantley
Ellicott City, Maryland
Posted: 02/13/23 07:03pm Link  |  Print  |  Notify Moderator
We do realize all houses built today in warm climates have central air conditioning. Those without central air survive with windows shakers.
The so called grid in the 1950's was not built for air conditioning.
Somehow the grid as kept up with advancements in technology and comfort.
The thought that the grid will fizzle out because of EV is short sighted.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Learjet
Louisiana
Posted: 02/13/23 07:31pm Link  |  Print  |  Notify Moderator
There is more to transformer sizing than what you mention. Transformers can put out more than their rating.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
ronharmless
The far side
Posted: 02/13/23 07:50pm Link  |  Print  |  Notify Moderator
The electrical infrastructure serving my house was installed in our backyard in 1953. The main backbone infrastructure has not been upgraded since being installed. Without a very expansive outside financial input, there won’t be a infrastructure update. My backyard is only 1 of a 150 million backyards. Power plants, substations, and transformers are one gargantuan cost, the 150 million last mile(s) are even bigger. No money no bueno.
Reisender
NA
Posted: 02/13/23 08:04pm Link  |  Print  |  Notify Moderator
Meh. BC hydro talks about this on their website. Any upgrades get done in the normal course of regular maintenance. They see no issues going forward as it is a 40 year transition that already started 10 years ago. I’m sure most modern nations won’t have a problem with the transition.
pianotuna
Regina, SK, Canada
Posted: 02/13/23 08:11pm Link  |  Print  |  Notify Moderator
I do use an autoformer at my brother's cottage even though there is a 50 amp service for my 30 amp RV. No load voltage is only 107.
I think he would still be able to do level 2 charging on that 50 amp circuit.
The cottage was upgraded when it was moved in 1970 to a 100 amp service. That has now been replaced with a 200 amp service.
He does have 5000 watts of solar panels on a grid tied system.
Regards, Don
Reisender
NA
Posted: 02/13/23 08:14pm Link  |  Print  |  Notify Moderator
You would have no problem with a 14-50 receptacle like. The EVSE might current limit if the voltage drops to low. There are sensors for that.
pianotuna
Regina, SK, Canada
Posted: 02/13/23 08:15pm Link  |  Print  |  Notify Moderator
Is the 25 kva input voltage only at 240? I thought it was a lot higher.
Page of 16
