cruising spud
Pennsylvania
Every time we replaced our rv tires, we also replaced our dually valve stem extenders, which we always bought from the Tireman in California. Well, the Tireman died several years ago. So, who makes a good quality valve stem extender?
Thank you.
deltabravo
Spokane, WA
Wheel Master has some at ETrailer.com
IAMICHABOD
Sunny So Cal
The ones you need are from Borg AKA Your Tire Supply. Dually Kit
They will look like this and come from a company that is the only one now making longer valve stems for Class C Duallys like the Tire man, I have a set from Tire Man that was the original maker of them and have been on my Class C for over 10 years with no leaks or problems. You can Check the pressure on all tires in a matter of minutes.
Valve stems
DO NOT put the braided extenders on, they will leak and if they come loose from their mount on the wheel they will cause a catastrophic air loss.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
cruising spud
Pennsylvania
I have heard good things about Borg extenders. NO braided extenders-got it. Thanks for the info.
toedtoes
California
Consider getting Cat Eyes. They equalize pressure between tires, but have an internal check valve to keep one tire from going flat if the other does. You can fill both tires at once. And you can easily see at a glance if your tires are low on air - no having to bend over and/or use a gauge.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Cummins12V98
on the road
Maybe your truck is different but I have ZERO issues filling or deflating my DRW tires. Proper double ended air chuck and pressure gauge. Extenders simply cause another potential failure IMHO.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
cruising spud
Pennsylvania
toedtoes-it looks to me like Cat Eyes are tire pressure monitors. Those we already have.
Just wanted to revisit which valve extenders to buy, now that Tireman has past away.
Thank you all for the input.
johnhicks
Wandering below the Gnat Line
Borg has worked fine for me since 2013.
-jbh-
toedtoes
California
cruising spud wrote: toedtoes-it looks to me like Cat Eyes are tire pressure monitors. Those we already have.
They are monitors yes. But they also connect both tires to one easy to reach valve. And have a valve check to prevent one flat tire from emptying the other tire.
johnhicks
If you do go with the Borg extended stems be sure to get the rubber grommets for the holes in the outer rim, for both stems, and you may need to secure them with a little silicone goop. The grommets prevent the stems from rotating and wearing on the edge of the hole.
