RV.Net Open Roads Forum: Tech Issues: Back in the dark ages !
 > Back in the dark ages !
wanderingbob
monticeeo, fla
Posted: 02/19/23 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
I believe that I was taught that all things being equal, that stranded wire would carry more current than solid wire ? Is that true or am I being misled ?
2oldman
NM
Posted: 02/19/23 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I won't annoy you by looking it up.
Dutch_12078
Winters south, summers north
Posted: 02/19/23 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
You're being misled... Given the same size wire, solid wire will carry slightly more current than stranded due to the spaces between the strands reducing the capacity. In practical use, the difference is not a significant factor in deciding which is the best choice for a given application.
Dutch
2001 GBM Landau 34' Class A
wanderingbob
monticeeo, fla
Posted: 02/19/23 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Also , I am sitting here ordering a 200 amp lithium battery and the proper charger , what do a shunt do and why do I need one ?. The battery is on the way , $ 600 bucks , wow , Boy I hope they do not quit social security until I get this paid for !
Dutch_12078
Posted: 02/19/23 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
A shunt is a small resistance inserted in line with the load that allows a much smaller meter to indirectly read the load without the total current passing through the meter circuitry. The meter simply reads across the shunt and uses a calibrated multiplier for the reading.
Boon Docker
Posted: 02/19/23 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
A shunt is used in conjunction with a meter to indicate what is going on with the battery.
Which will indicate the amps put into the battery, amps taken out, state of charge etc.
PastorCharlie
NC
Posted: 02/19/23 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
More wires give more surfaces for current to travel on. Finer the strands the greater number of surfaces. Considering the same size of wires.
ktmrfs
Portland, Oregon
Posted: 02/19/23 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
ok if a stranded and solid are the SAME wire gauge, current carrying capability is the SAME. e.g. both AWG 14.
2011 Keystone Outback 295RE
jkwilson
Indiana
Posted: 02/19/23 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Current does not travel on the wire surface until the frequency gets to about 20 KHz. It is not an issue for power.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
ScottG
Bothell Wa.
Posted: 02/19/23 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
A shunt allows you to measure current flow. So you can tell how much coming out of or going in to your battery. If you don't plan on monitoring these things then you can do without it.
