RV.Net Open Roads Forum: Tech Issues: Back in the dark ages !
 > Back in the dark ages !
C Schomer
Pueblo West, Co.
Posted: 02/20/23 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I had two electrician uncles... both long gone, now! They said stranded wire ran a little cooler. Whatever, but I still go by the regs. Craig
Boon Docker
Posted: 02/20/23 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
johnhicks wrote:
I've read that charging lithiums with an ordinary alternator can smoke your alternator. Investigate before doing that.
Charging a couple 100 ah batteries will not hurt the alternator.
It's when you try charging a large battery bank that exceeds the alternator capacity that you run into problems.
time2roll
Posted: 02/20/23 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Wire carrying capacity for DC and 60hz electricity will depend on circular mils (copper cross section) not stranded or solid. Also depends on insulation heat rating and if the wire is bundled in a sheath such as NMB, in conduit, or in free air. However this ampacity rating would be used for fuse selection. Selecting the right wire will also depend on the length and amp load to avoid excessive voltage drop. Usually one or two sizes larger will be appropriate vs minimum for ampacity.
Also smaller wire will tend to allow more ampacity per circular mil of copper as there is more relative surface area to dissipate heat. Need to study a wire vs ampacity chart. Very high frequency AC will have some "skin effect" but nothing to think about in an RV.
May not need a shunt (battery monitor). If the battery has bluetooth it may already have an internal shunt. Voltage is still an indicator of remaining capacity although voltage is very flat from 25% to 75%. Depending on the usage and charging patterns the system may stay above 50% and mostly get ignored.
Alternator is only subject to overload/heat damage if the connection is short, fat and no fuse. More likely to have lower than desired charging vs overcurrent situation. Many jump on a DC-DC charger when it is not really needed. Install the battery and measure the situation before adding more equipment.
I pulled my trailer 5 hours today and my alternator is fine. My internal BMS was indicating 99% full. (no harm in a short charge unlike the old lead-acid)
675w Solar pictures back up
Posted: 02/21/23 05:00am Link  |  Quote  |  Print  |  Notify Moderator
0
There are many myths designed to scare you into not improving your life.
Alternators come in two flavors.. both are current limited and the myth is since Iithiums can take a rapid charge they will draw more than the alternator can deliver and burn it out... Nope. alternator knows what it can deliver and won't exceed that amount.
Li's however do take a slightly higher voltage.. Oh that could pop a diode.. Again nope.. it won't.
wanderingbob
monticeeo, fla
Posted: 02/21/23 06:05am Link  |  Quote  |  Print  |  Notify Moderator
The original poster here ! I want to thank you all for your help . What I am in the process of doing is installing a 200 amp lithium battery and the proper converter . We consider our selves as " travelers " , not campers , not boondockers . We tend to spend the night where ever we are when we get ready to stop , maybe Walmart but could be just as easy a church lot , police station , hospital , cemetery . What we were hoping to achieve by going with lithium is the ability to run the furnace or a couple of fans all night with out running the batteries down . We travel in a Ram 2500 with a topper , under the topper is mounted a 3400 watt generator , a 35 gallon water carrier , 2 electric bikes and a pancake compressor . We like back roads and stop at all small museums , yard sales , towns with funny names , historic sites , battlefields . We just wander and will go to a campground every 5 or six days . Planning a 5 month trip next summer/fall . Thank you all again . I have owned RVs for 40 years but this " new Tech " is confusing to an eighty year old .
ktmrfs
Portland, Oregon
Posted: 02/21/23 08:42am Link  |  Quote  |  Print  |  Notify Moderator
jkwilson wrote:
PastorCharlie wrote:
More wires give more surfaces for current to travel on. Finer the strands the greater number of surfaces. Considering the same size of wires.
Current does not travel on the wire surface until the frequency gets to about 20 KHz. It is not an issue for power.
Well, no skin effect exists for ALL frequencies above 0 Hz. (DC). It's just that for it to be noticeable for many conductor sizes it needs to be pretty high frequency. However, Power companies need to deal with skin effect even at 60Hz. given the size of conductors they use.
2011 Keystone Outback 295RE
S Davis
Western WA
Posted: 02/21/23 10:35am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
0
It might not exceed its max amperage but they can over heat and burn up trying to put out max amperage at idle, unless they have temperature protection. I charge a pair of 280ah LifeP04 batteries and they will take all the amperage I can throw at them until about 95% SOC when they start tapering off the amperage.
valhalla360
No paticular place.
Posted: 02/21/23 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
jkwilson wrote:
Tvov wrote:
I was always told that solid wire conducts / allows more electricity / power. That is why houses are wired with "romex", solid wire, instead of stranded wire like extension cords. Considering how difficult romex is to work with, everyone would prefer stranded wire if it would work better.
Well, that is the simple explanation given to me by electricians!
Solid wire is cheaper to make and easier to connect in household wiring. Stranded wire is better where flexibility is important such as lamp cords or in vehicles.
How many 7.0 earthquakes does the average house go thru per year and how many equivalent events happen in your average RV.
For most practical purposes, once the house wiring is in place, it will never move again to any meaningful degree. Bouncing down a road at 60mph, your RV wiring is undergoing hours long 7.0 equivalent earthquakes every time you travel.
The smaller diameter of the individual strands results in far less work hardening and fatigue damage compared to solid wire.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Chum lee
Albuquerque, NM
Posted: 02/22/23 11:51am Link  |  Quote  |  Print  |  Notify Moderator
^^^ Plus, in USA residential applications, (which generally use romex solid core wire within the walls) where does the temperature match what is typical in an automotive engine bay or along an exhaust system? (catalytic converter) That's right, . . . . in oven/rangetops, water heaters, compressors, furnaces etc., which all use multi strand wire internally, even though they are permanently installed in a residence.
Ambient temperature is important!
Chum lee
deadticket8
All over
Posted: 02/26/23 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Wandering Bob! That's my style of travel too. I will install 300 watts of panels with 200 AH batteries. Like to wander, boondock, see some sights. I dont want to spend what would be a large down payment on a condo so I can live like I am in a condo! But Lithuium is new to me. Sure seems like they are more cost effective than wiring 6 volt flooded batteries in series. I am learning! Happy trails to you and yours!
