RV.Net Open Roads Forum: Fifth-Wheels: Axle and tire?
 > Axle and tire?
Cummins12V98
on the road
Posted: 02/20/23 09:56am Link  |  Quote  |  Print  |  Notify Moderator
garyp4951 wrote:
GY Endurance made in USA is what I have after 2 Westlake tires blew that were 3 years old with 5k miles.
You beat me to it!!!!!!!
YES the GY's have a stellar record. Try to find a non road hazard failure.
Put a set on my Boat Trailer Summer 2017, they are going strong with well over 25k and plenty of tread left. They do have a 87mph speed rating. OH and if it matters are US Made.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
tntcrock
Southwest Louisiana
Posted: 02/20/23 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Running ST235/80/16's
Yes, I'm towing level. I'm also going to add tire pressure monitoring system to may trailer and truck, any suggestions?
JIMNLIN
Oklahoma
Posted: 02/20/23 11:53am Link  |  Quote  |  Print  |  Notify Moderator
My then new 32' 1997 5er with two sides and 6 lug 5200 lb tandem axles came with ST225/75-15 load E tires.
I sold the 15" ST may pops/wheels and went with 6 lug 16" trailer wheels and BFG Commercial TA/2 LT215/85-16 E at 2680 lb ....110720 lbs total capacity.
Ran the first set for 55k miles per set ....2nd set for 53k miles and with 48k miles on the 3rd set.
I'm looking at a new set this spring. No issues at all at legal highways speeds
WE make long trips and mileage adds up.
There is no better tire for 5200 lb trailer axles than a commercial grade LT 16" E like we ran on our 3/4 and one ton trucks. With 15 and 16/32" of tread depth they last longer (miles of service) than any 16" ST E tire on the market.
I sure wouldn't put a load F or G on any of my rv or non rv work trailers with 5200 lb axles.
C Schomer
Pueblo West, Co.
Posted: 02/20/23 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
A previous 5er was 9600 gvw and it had 6 lug 15"s on 5200 axles and two sets of ST tires went kaboom in 48 months, just like clockwork. Having enough capacity for the FULL weight of the 5er and storing it on jack stands and using tire covers, with the second set, didn't help a thing.
I got 16" wheels from etrailer and LT 16" tires from Discount Tire, for a total of exactly $800, and never another tire problem. Craig
azdryheat
Tucson, AZ
Posted: 02/20/23 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, dump your tires if they say Made in China. I run 16" Michelin XPS RIBs. Zero problems in 9 years of towing all over the USA.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
laknox
Arizona
Posted: 03/02/23 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
tntcrock wrote:
I have a 2006 Montana Mountaineer that has GVWR of 12275lbs but has 6lug 5200lb axles. This doesn't seem right to me but I guess they deduct some for pin weight. It came with Load E tires but I've had blowouts and thinking of going up to load F or G. I'm tired of tire issues and damage. I'm fanatic about tire condition and psi, I'm always on top of it. Last blowout tire was less than 2 years old. I've also had a new set all roll the belts and have to be replaced within a year, probably one trip on them, they bulged out in middle tread.
I'm not a GY fan, but put a set of Endurance on my FW. So far, I'm happy, but I did notice that the tread depth is noticeably less than other brands. Given that ST tires rarely wear out, not a huge issue, but if you tow in the wet a lot, you might want to consider something else. I'd love to go to LTs but most places won't install them unless the tires have a load rating that meets or exceeds the placard, so you end up having to take the wheels off, take them to the tire shop for the swap, then put them back on.
Lyle
2022 GMC Sierra 3500 HD Denali Crew Cab 4x4 Duramax
B&W OEM Companion & Gooseneck Kit
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
ferndaleflyer
everywhere
Posted: 03/03/23 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I am not good at all the technical advice here but I’ll submit real life, no BS, experience. My truck and trailer together weigh 22,000lbs. In 10+ years and over 100,000 mi I had 2 tire problems, 1 the whole tread came off of the tire but it was still full of air and the other was road debris. I tow level, check air often and here is where I lose all the “experts”. Other than what came on the trailer when new I have ran 235-15 Good Year wranglers from Walmart. This is a 3 axle trailer. I once had a trailer that blew 9 tires in th 6 months or so I owned it, don’t know why.
JIMNLIN
Oklahoma
Posted: 03/03/23 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
In the late '90s and early '00s Goodyear Wrangler HT came as OEM on several rv trailer brands with 5.2k and 6k axles. Most were LT235/85-16" load E size.
Then in the mid '00s Goodyears started having issues with their G614 load G and the Wrangler HT tire lines.
By the late '00s to Goodyears credit both had their issues fixed (mostly tread loss).
deltabravo
Spokane, WA
Posted: 03/03/23 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Tireminder or TST. They both make great systems.
goducks10
There
Posted: 03/04/23 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Not sure what you paid for them 9 years ago but today they're off the charts expensive.
https://www.tirerack.com/tires/tires.jsp........ll=Blackwall&partnum=385R6XPSR&tab=Sizes
 > Axle and tire?
