RV.Net Open Roads Forum: Travel Trailers: Controller for Lithium Batteries
 > Controller for Lithium Batteries
deadticket8
All over
Posted: 02/22/23 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone. I will be installing a modest solar system on my trailer consisting of 300 watts solar with 200ah of lithium batteries. I am trying to make a decision on the controller. I'm looking at Epever tracer that says it is lithium compatible. But as in many controllers reviewers say tricky to program for lithium. Any thoughts? I should mention I used a Renogy Rover on my last trailer with flooded batteries and it pooped the bed in the middle of my long journey. So I am leary of them. And not looking to break the bank.
StirCrazy
Kamloops, BC, Canada
Posted: 02/22/23 08:32am Link  |  Quote  |  Print  |  Notify Moderator
its hard to say.. I use the renogy rover 30 amp MPPT for 3 years now and it has been nothing but perfect. Now everyone I know is using them and no one has had issues so maybe you just had a defective one, how long were you using it till it crapped out? I know of 8 of them that have been going between 2 and 3 years now from my friends getting them after I did. for there price you could buy two of them for the same as one victron.
If you don't want to try another thats cool, I would recomend Victron then, as I suspect the Epever is mad by the same manufacturer as renogy, but renogy has a custom plastic cover. if you look at the shap, heat sink, mounting, display, termanals, there all the same.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Second Chance
Wherever...
Posted: 02/22/23 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Victron makes solar charge controllers which have a good reputation - recommended by Battle Born for their batteries.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
2oldman
NM
Posted: 02/23/23 07:38am Link  |  Quote  |  Print  |  Notify Moderator
You don't want 'tricky' to program. But a programmable controller is what you want, one that can either drastically shorten absorb time or eliminate it completely.
time2roll
Posted: 02/23/23 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Epever would not be my choice. I read too many troubles. One step below Renogy.
Can't go wrong with Victron.
I have a Morningstar that is going strong close to 15 years. Very easy to reprogram for lithium.
675w Solar pictures back up
StirCrazy
Posted: 02/23/23 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I think there a lot more than one step below renogy haha..
Steve
deadticket8
All over
Posted: 02/28/23 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
I just spoke with Morningstar. Lithiums can be complicated and they have good tech support. I will follow up later. wicked expensive though.
Also looking at Victron Smart 100/30. I watched a video and it seems not too hard to set up for lithiums. One video suggested setting absorbtion rate at around 13.4.
* This post was edited 03/01/23 07:09am by deadticket8 *
Boon Docker
Posted: 02/28/23 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Epever that has been working fine for the last 14 years.
